Ok... Suspension people > I got 215/17-45 tires- Eibach Pro-Kit or H&R w/Stock Struts
Old Jul 4, 2004
ImPulse's Avatar
ok, im going to be buying some brembo rotors soon and at the same time, iam going to order some springs... Which should I get? I heard that If I lower my car more than an inch my tires will rub? So... Which springs would be better?
Old Jul 4, 2004
Yakkolio's Avatar
Yakkolio is an unknown quantity at this point
i didn't rub with a prokit with the same tire and rim size
Old Jul 4, 2004
infinite's Avatar
infinite is an unknown quantity at this point
i have 215/40/18 tires with neuspeed sport (1.75 F 1.5 R) + ingalls camber kit all around and i don't rub at all.
Old Jul 5, 2004
AdmireMyGr8ness's Avatar
SuperMod a.k.a ~AMG~
AdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond repute
I was rubbing with 205/40/17 - Suspension Techniques 1.75" drop and KYB struts. I went with Ground Control coil-overs and the rub has stopped and I still have a tight stance.
Old Jul 5, 2004
Yakkolio's Avatar
you have a 98 civic, the drop compared to a 2001+ will be different
Old Jul 5, 2004
Um yeah... I was mearly stating what happened to me and suggesting he try coil-overs if he's concerned.
Old Jul 5, 2004
Yakkolio's Avatar
i wasn't trying to be a smart a$$ i was stating that you had a 98 civic, so he wasn't misinformed about his decision.
Old Jul 6, 2004
fo50rd's Avatar
fo50rd is an unknown quantity at this point
I have Falken 215/45/17's and a ProKit on my 02 sedan. With the ingals camber kit on the rear adjusted straight up...I rub. Had to give them a slight lean in for the fix. 11K miles later, though, my new Falken's are scalloped on the rear. The Fix? Rotated them to the front (which wore fine, no camber adjustment or alignment ever given) and used the ole baseball bat to roll the fender lip trick. Adjusted out the ingals a bit more...no rub...and should wear nicely.
Old Jul 6, 2004
Green Civic's Avatar
I have the pro-kit and love them.
Old Jul 7, 2004
astigmatik's Avatar
astigmatik is an unknown quantity at this point
prokit if you have skirts, h&r if you don't. the ground clearance will be about the same.
you should not rub with either drop, since these springs still leave fender gaps.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Strycker
Aug 2, 2015 08:40 PM
17
Jul 23, 2015 11:48 PM
mrohitredd
Jul 21, 2015 09:26 AM
Ariah J. Davis
Jul 20, 2015 07:15 AM
