neuspeed springs question
Old Jun 13, 2004
doubledeuce2k2's Avatar
this is an unusual question, but i need to know what color neuspeed springs are for our cars. i bought the car with springs on it, they are red, and i know he had both sport and race springs on it at different times. the drop is a little low for my tastes, i just wanted to know how low it was before i chose other springs. thanks a lot, its a 2001 civic btw.
Old Jun 13, 2004
VNlilMAN's Avatar
The Standard One
sports come in red, race come in red and yellow.
just jack the car up and look for a part number...
tell me what size tires and how much gap and i'll try to guesstimate
Old Jun 13, 2004
i have 205/55/16 tires on there, the car is 5 lug now so i don't know if there is an unusual offset or not (rsx stock wheels). on the back there is really no gap to speak of, the wheel is tucked in under the fender a bit, which bothers me for the poor roads/numerous rail tracks i drive over.
Old Jun 14, 2004
VNlilMAN's Avatar
The Standard One
the rear can vary alot.. how about the front?
you bought the car with 5 lug??? crazy...
woah wait you have a sedan? oye that changes things... if you tell me the front i can give you a better guess. for the front 0-.5 finger i would say race. 1.5-2 finger gap i would say sports. but then again i'm pretty skinny . Try checking the part number on the springs to make sure...
Old Jun 14, 2004
yeah i guess i will check the part numbers then.
i bought a 2 door 2001 civic with rsx-s tranny, axles, and, um, engine. i also have a 2002 4 door (first car). so i bet that has you confused.
the rear varying a lot is what pisses me off. is this just a neuspeed thing or will i get this with any brand? any brands that are more consistant than others (i might end up with tein h-tech if i can't find one that will be high enough for my needs...)? also, i get a lot of squeaking in the rear. the previous owner said he took the "rubber pieces" off the stock springs and put them on the new ones. he was unsure if this was neccesary or not, and was also unsure if this was causing some of the squeaking. i apologize for my lack of knowledge in this area, but i have been reading a lot and doing my homework
Old Jun 14, 2004
clownprince's Avatar
Ricerus Maximus
If it's tucking tire in the rear I would guess Race. Those are the only Neuspeed springs that I have seen that go that low. Another thing to consider is are the shocks Koni's or are they stock. A blown stock shock will also cause it to sit a little lower.
Old Jun 15, 2004
i do have koni's all around.
Old Jun 15, 2004
ok i took some pics to illustrate how much more front gap i have.
Name:	front wheel.JPG
ID:	31094   Click image for larger version
Name:	rear wheel.JPG
Old Jun 15, 2004
VNlilMAN's Avatar
The Standard One
LOL it almost looks like a mixture of both. Imma have to go with sports though. Reason why i say the rear can vary a lot is the rear is more sensitive to weight(whether it be things in the car/trunk or if its on slanted ground). also yeah koni's have 2 different perch settings, along with a few other variables. but yeah just check the part number, shouldnt be too hard to see.
Old Jun 15, 2004
pbfoot's Avatar
if you say theyre red and the front is that high, id say its sport also. race you would be much lower in the front, from what ive seen.
Old Jun 16, 2004
i'll try adjusting that perch setting i guess. i just had trouble believing these could be sports (1.5 in rear) with that little gap, i couldn't imagine 3 inches if that was the case. is there a link (pref. with pictures) showing this perch? what exactly would i be adjusting?
i will probably get diff. springs anyways, i want a cushier ride, but i don't want to have the same issue if it is the way the shocks are set up.
Old Jun 16, 2004
gc30's Avatar
gc30 is an unknown quantity at this point
Hey Prod,
u said u got koni yellows and race springs? does your back rub (rear fenders)?? cause i justhave sports and whenever i carry a heavy low there's less than 0.5 finger gap in there but it's sticking out =) i also run 215/45 -17s
Old Jun 19, 2004
ok, this might look weird, but i'm planning on putting the stock rear springs on the car, which should raise it around 1.5". is this safe to do? i know it will raise the rear end, but is mixing a set of springs going to cause unforeseen handling problems?
Old Jun 21, 2004
abmerop18's Avatar
Jam out with your clam out.
i would say no to mixing springs. they ahve different spring rates and that might mess everything up.
Old Jun 22, 2004
chrisleecool's Avatar
^^^ I agree...(by the way, did u buy your car from a member of this site?)
Old Jun 22, 2004
VNlilMAN's Avatar
The Standard One
the front is going to be stiffer than the rear than. you want the opposite, the rear stiffer than the front.
Not to mention the rear is going to be really² high
Old Jun 22, 2004
abmerop18's Avatar
exactly
btw, i like that little touch with the really squared lol
Old Jun 22, 2004
VNlilMAN's Avatar
The Standard One
haha glad you got a kick out of it
Old Jun 22, 2004
Green Civic's Avatar
Mixing springs is usually a bad combo. Either put all stock or stay the way you are.
Old Jun 22, 2004
ok, i'm gonna go with a set of different springs then. yes i did get it from a sitemember (bighippo22). probably some tein h-techs or maybe eibach prokit.
Sep 26, 2023 06:44 PM
loosescrew84
16
Aug 11, 2015 07:08 PM
Curtchuk
Aug 5, 2015 02:14 PM
mHo2
Jul 27, 2015 12:57 PM
Ccoop87
Jul 9, 2015 03:26 PM
