RSX rear sway and front sway? good combo?
Hey,
I got a 03 Civic ex. I dont know what mm front sway, but im getting the rsx rear sway. I can get the rsx front sway, would that be a good combo to work with? Lemme know asap. I dont know what mm the front sway is but i think that the rsx is bigger so it would be a something mm front/19mm rear. is that good? Im new to it so help me out. Thanks to everyone in advance
you might find the 19mm rsx rear bar coupled with the 15.9mm front bar to be a bit too much. look around, some people have commented on this.
I am running a 17mm rear from 04 civic si with my 15.9mm front. I'm liking it so far. better than the 15mm rear i was using before from 03 si. 19mm might be a bit too much. depends on your driving preference of course
Back From The Banned!
This has been discussed before. It depends on how you want your set up to be. If you want more oversteer when you lift of throttle in corners, get the rear 19mm bar and stay stock up front. If you dont want that, get a thicker front and rear bar. A lot of ppl here either have the Progress rear sway, RSX rear sway bar, or Neuspeed.
Originally Posted by ati9700pro
i heard that it did fit,hmm, mabey we need some clairifacation on this
Next time use the SEARCH function up to to find the answers. Here are few things I found
Originally Posted by robbclark1
yes it has a 16mm front sway bar. Yes it will fit a 2001, but unless you are racing there is no need to go from a 24.5mm (2001) to a 16mm (2003)front sway bar. the DX, VP and HX i don't think have any sway bars so you would need to mount those.
No you can't fit a RSX or Si front sway bar. The list of current aftermarket sway bars are in the FAQ which can be found in my signature.
Originally Posted by Da2K1
The RSX front sway bar will NOT fit, unless you pull the Cat to one side & relocate the hangers. If you look at our front sway bar, it has a bend in the middle, as that's where the Cat is. The RSX has the bend offset to one side. I've tried this.
Originally Posted by Grey
Hmm... Let me modify my statement then. It will fit the DX/LX/HX.
Yeah, I didn't think of the cat. I have an LX. That's why. I bought the Progress front sway bar and it's the same one as that for the RSX. Progress says it fits all Civics. I noticed that the bend is in fact pushed over to one side. What's the truth? Will the RSX front sway bar fit an EX Civic? Who knows for sure? Who's tried it?
autowill
May 15, 2015 11:36 AM
oneheadlight
Apr 29, 2015 11:30 PM
superstanko
Apr 28, 2015 04:38 AM
