Lowering???
Old Jun 8, 2004
Kaos-style's Avatar
Kaos-style is an unknown quantity at this point
Lowering???
Will the lowering springs for 2001-2003 also fit the new 04 models? 2 me its looks like the same set up.
Old Jun 8, 2004
civicfrenchie's Avatar
civicfrenchie is an unknown quantity at this point
yes they will
Old Jun 8, 2004
jttegx's Avatar
OMNES AD UNUM
depending on which springs, you should always verify by emailing the company site to make sure. you dont wanna end up buying something n reselling for like half the price.
but specifically, which springs?
Old Jun 8, 2004
Kaos-style's Avatar
If i had 2 narrow it down. Id say. Eibach Sportlines or H&R Sport.
Old Jun 8, 2004
robbclark1's Avatar
Retired suspension supermod.
they will fit.
Old Jun 8, 2004
2004 =same geometry in suspension than 2001-2003...so no problem..in 2002 they increased the diameter of the insert-strut to 55mm from 50mm because of the numerous problem with the front struts leaking problems...it didn't change anything for the springs cause there's no diff between 2001 and 2003 (after that change) so 2004 is the same 55mm struts with 16mm camber bolt...don't worry
if you have a sedan neuspeed are the only one who make a spring different for the sedan...if you have a coupe anything goes...h&r sport will gave you a good ride...i have experience with neuspeed sport and they're
Old Jun 14, 2004
Calidan's Avatar
Calidan is an unknown quantity at this point
They will fit. I just put on some springs that were originally on an 02, and I have an 04. So there you go.
Old Nov 22, 2004
el_ben2's Avatar
CivicMexicano Is My Daddy
el_ben2 is an unknown quantity at this point
so i can use any springs on my sedan?
i mean... i dont have to worry about if its for coupe or sedan?
Old Nov 22, 2004
Mr.Modify's Avatar
Originally Posted by robbclark1
they will fit.
yup...springs will fit.
Old Nov 22, 2004
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
if the spring description says for coupe, then its for coupe. if it doesnt mention anything about body style then your set. but rumors has it that the eibach sportlines sag in the rear on sedan models. coupes were fine i believe. search it up.
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
bhollie
Sep 22, 2015 11:08 PM
