How long will KONIs last?
Old May 22, 2004
Callawaygirl's Avatar
Callawaygirl is an unknown quantity at this point
hi i just fitted my 03 Civic EX with KONI yellows. Do you know how long can these last for normal street driving? many have told me about 1 year and I feel this is very short lifespan. What's your comments? Thanks!
Old May 22, 2004
Vinh's Avatar
at normal drop height...it should last couple years depending on street conditions
but koni should have a warranty
Old May 22, 2004
Zzyzx's Avatar
Autocross Junky
Konis, on the street should last Many many years.
Old May 23, 2004
flotsamm's Avatar
Yup, life time warranty was one reason why I bought a set. I was told Koni will ship out another set to you first, then later you ship back the defective ones so that you wont have any down time.
Old May 24, 2004
Diablo's Avatar
Diablo is an unknown quantity at this point
Ive had my Koni for about 3 months and i have replaced my front shocks about 3 time. they leak around the adjustment screw or were the shock goes in and out. but like every one says they replace with no problem aslong as you have $112.00 to put up front, well thats konis new rule.
Old May 24, 2004
flotsamm's Avatar
Eek.. 3 times? Damn thats some bad luck. I think your the first I've heard of that had to replace them so many times. 112 bucks up front? I guess if its refundable I'd pay it.
Old May 24, 2004
dj02's Avatar
well the problem diabol is haveing, is from the instalation. not from koni, remember the front ones are just inserts. not a full strut like the rear. you have to cut open the oem struts.
Old May 25, 2004
Diablo's Avatar
No it isnt from instalation if it was something i did Koni wouldnt refund me the money its just bad luck i guess. they inspect the defective strut before they refund the money
Old May 25, 2004
RW_Blaze's Avatar
RW_Blaze is an unknown quantity at this point
my rear is squeeky and making alot of noises.. sounds like its hitting sumthin everytime i hit a small or big bumps... there's like no play and its in half firm.... i dunno if its blow or what!? how can i return them to get new ones
Old May 26, 2004
Diablo's Avatar
Go here http://www.koni-na.com/contact.html and fill it out let them know what the problem is and wait till they get back to you. Most likely this is where they will send you http://www.koni-na.com/warranty%20policy.htm
Old Jul 17, 2004
streetglower's Avatar
www.koni-na.com/warranty Then click on warranty return procedure and fax them that info and they will call you back with RGA #.
Old Jul 20, 2004
v8eaterokv6's Avatar
i have a new home do u
i put konis in my rear and they lasted about 3 months. the ring that holds the spring perch on sheared off one side and when i installed my teins i noticed the other side was about to shear compleatly off too. koni was willing to replace them but you need a recipt and my ex girlfriend has mine and well im sol
Old Jul 20, 2004
flotsamm's Avatar
You might have an early version of the rear perches. The newer ones dont seem to have this issue anymore.
Old Jul 20, 2004
i just got them in november
Old Jul 20, 2004
dirtySAMURAI's Avatar
I log in from time to time
my rears are busted. just about 4 months and theyre busted.
Old Jul 20, 2004
for all of you that had yours bust at 3-4 months, did you install them yourselves or a shop install them?
Old Jul 20, 2004
i installed them myself
Old Jul 20, 2004
that might be why, not saying you did it wrong, but I had a shop do it that had experience installing them on the 01-03 civic
Old Jul 20, 2004
well i know i put them in right they worked great till i hit a pot hole on the interstate with the passenger side and destroyed that one and then i ordered the teins and when i pulled the drivers side i noticed it was failing too.
Old Jul 20, 2004
I dont know then
Old Jul 20, 2004
while i had them i ran the **** out off them. but i love the teins they rock
Old Jul 21, 2004
flotsamm's Avatar
Did you have the new rear perch design with cut groove in it for the circlip? The new perch has a groove in them that traps the circlip so it has no chance of popping out. I think around November/December was the time they started distributing the newwe design.. not sure.
I've had mine on for a more then a few months now and no problems yet.
WaryDriver
Aug 8, 2015 05:08 PM
Green02civic
Jul 27, 2015 10:48 PM
viperGTS
Jul 27, 2015 08:40 PM
