Two Questions
7th Gen Photographer
Two Questions
ONE:
Does anybody with TEIN Type SS's have a strange noise like the springs popping when turning the wheel at a dead stop or slow crawl? As best as I can tell... its because the steering rack attaches to the strut, so when it turns, the noise is the spring rotating on the adjusters.... and if i am right or wrong... is it bad that it makes that noise?
TWO:
how much lower ground clearance does an X brace give you? I have my car pretty freakin' low and i somehow, miraculously don't scrape... however im a fraid i'd smash the X brace on everything if it lowers the cars clearance by more than an inch.
TWO:
I have SS and i have the popping noise too. Its probably because of improper install but I know a lot of people have noise issue with full coils. Best bet would be to just get used to it
1) check all the locking nuts to make sure they are tight.
2) you will still have plenty of room, but you still might bend it. I know someone with an RSX who bent his where the screw comes in and he can't get it off now.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
junkyardguy
Sep 2, 2015 06:07 PM
