RSX Sway Bar & Exhaust
Old May 10, 2004
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Hey everyone, im getting a new APEXi World Sport 2 in about a month and I am considering getting an RSX Rear Sway Bar because the rear of my car is really loose when take corners fast. If I get the RSX Bar, will it clear hitting the exhaust? Also, the rear suspension squeaks when I go over bumps slowly, or when im just pushing up and down on the trunk. Does that have something to do with the sway bar? Thanks.
Old May 11, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
Most likely wont clear
Old May 11, 2004
Zzyzx's Avatar
Autocross Junky
Um, Describe how the rearend of the car is loose on turns... Because the larger rear bar is going to make the car want to oversteer sooner. SO if the car is oversteerign now it may not be a good thing to get.
what else have you done with your suspension?
Also, A cars tendency to oversteer increases as speeds increase. so that may be the issue. Check your alignment and see if you have any toe Out on the rear, if so, set it to 0 toe, or a little toe in. that should settle the rear end down abit.
Old May 13, 2004
ZSKCivic01's Avatar
Extreme Member
It just feels loose, the rear sways over to the side when I take turns a little faster. I have a front upper sway bar on my car, thats pretty much it. If the bigger sway bar doesn't stiffen the suspension in the rear, what does it do then?
Old May 14, 2004
Zzyzx's Avatar
Autocross Junky
Does the car Oversteer (Fishtail)? hows your alignment (Proper alignments can make a car handle Like Night and Day)
Old May 28, 2004
ZSKCivic01's Avatar
Extreme Member
Yea, the rear on my car tends to oversteer. I have been gone for the past week, and I was in a part of texas that had winding back roads. I was taking a corner going about 30-35 that curved a little less than a 90 Degree angle and the rear skidded off road and I lost control of the entire car. Luckily nothing happened, but the rear suspension just seems to be loose, not helping to provide enough downforce on my tires or something like that. I do have aftermarket Konig Rated R rims w/ Khumo tires.
Old May 29, 2004
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
If your car tends to oversteer and you would like to correct it get a larger front sway bar. But like ZZyZx said have your alignment checked. You could also check to make sure your front endlinks are still intact cuz if they're broken that could lead to oversteer.
Dave Brabant
20
Oct 6, 2015 12:44 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
Viczhou
Sep 2, 2015 07:55 PM
