Spring Compressor Necessary?
Old May 7, 2004
blu03civic's Avatar
blu03civic is an unknown quantity at this point
I bought some tein s-tech lowering springs and i was wondering if it was necessary to have a spring compressor. Any help would be great. Thanks.
Old May 7, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
It would be wise. And considering autozone rents them out for free (just leave a deposit), there's no reason not to have them on hand.
Old May 7, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
I would recommend using one, unless you like having the spring shoot out and nailing you in the face or something else.
Old May 7, 2004
dj02's Avatar
haveing one is a good tool. but not necessary ..quick diy....... for the front un bolt the 2 lower bolts first along with tie rod and break line. then un bolt the the top bolt and tada spring pops right out with out anything hiting ur face loll as for the rear take out the whole set up lay it down "sideways" on the ground and put ur foot on it and unblot the top nut and there u go dont be scared about the rear one nothing will happend just wach for the nut cuzz sometimes when it pop's it can go pretty far.......
Old May 7, 2004
VNlilMAN's Avatar
The Standard One
thats why just put a towel over it while your doing it... i doubt the nut will shoot through the towel...
If you look at the DIY there's a little clip of a guy taking the nut off without a spring compresser.. you'll see it barely pops off
Old May 8, 2004
blu03civic's Avatar
yeah i was trying to look at the diy but it took forever for the pics to load on 56k and then the pics would turn into x's so yeah
Old May 8, 2004
Jrfish007's Avatar
Yeah.... like prod said, for free, why not have one? Now just to get mine on...
Old May 8, 2004
blu03civic's Avatar
yeah true...i figured if i'd get one and if i use it i use it...if i dont then no loss.
Old May 8, 2004
Aznnp77's Avatar
All Show No Go Sedan
Aznnp77 will become famous soon enoughAznnp77 will become famous soon enough
The fronts you can replace without a spring compressor, there is no resistance of the spring and the strut. The rear though, you will not be able to compress yourself unless you have at least a couple of friends with you.
You could however make a DIY spring compressor with a shirt though hahahaha. If you're reading this, remember MEX?
oh yea, it was a $40 deposit for the compressor, not $20. But no time limit to return or anything, I kept mine for over a month.
Old May 8, 2004
blu03civic's Avatar
with a shirt? lol...wtf?!
Old May 8, 2004
VNlilMAN's Avatar
The Standard One
using a spring compressor is a waste of time... the one from autozone is so thick that when i tried using it to put the lowering spring on, it got squished by the coils and i couldnt take it off so i had to compress them again in order to take them(the spring compressor) out.
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
tavisc
Sep 15, 2015 07:46 PM
BJB
Sep 14, 2015 11:16 PM
