Alignment Data
Old May 4, 2004
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
Alignment Data
What camber/toe settings are you guys running on at a drop of about 2" front and back ? Anyone here has a print out of their 4 wheel computerised alignment ? Any recommendations on settings for better handling ?
Old May 4, 2004
robbclark1's Avatar
Retired suspension supermod.
What are you willing to compromise? What is the treadware on your tires.
I say -.75 front, -1 rear, 0 toe all around or 1/16 toe in.
Old May 4, 2004
Zzyzx's Avatar
Autocross Junky
Robb, Run less -camber on the back, it will help the rear rotate..
alignment is kind of a personal thing. as in what one person likes may be to much or to little for another. Like RobbClark said, what are you willing to copromise?
Me, I plan on running -1 to -1.5 in the front half that in the back -.5 or -.75, a 16th toe out in the front and mayby 0 or a 16th toe in on the back (depending on if the car is too loose or pushes.)
On a side note, I also Run an 89 Si for autocross, and we have about -3 deg camber on the nose and about -2 to -2.5 on the rear, with 1/16th toe out on the noes and 1/16th toe in on the back
Old May 4, 2004
robbclark1's Avatar
yeah I know to run less negative camber in the rear, but when you are talking about a daily driver where the brunt of the turning is done by the front, you get some quicker wear there. You are running an autox prepped car daily. he may just want to get a little bit of extra handling out of his daily driver and not race it. He may not also want the rear to rotate as it can be dangerous. the numbers i posted are mild numbers that someone would want to drive daily, i think. if it was a honda dealer they would set it to as close to 0 all the way around for camber and give some toe in.
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
Bruce2
Sep 21, 2015 08:01 PM
TheRiddicles
Sep 21, 2015 01:28 AM
