Ingalls front camber kit
Old May 3, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
The product comes with two bolts. While the oem camber bolts are two per side. Do I just replace the top or bottom bolt ? or do I have to order another unit ?
Old May 3, 2004
robbclark1's Avatar
Retired suspension supermod.
the OEM camber adjustment is just the top bolt.
Old May 3, 2004
MrWong's Avatar
Bushido
I see, what is the bottom bolt for ?
I was searching though the forums and some people say you can install one bolt or two bolts, is there a difference ?
Old May 3, 2004
robbclark1's Avatar
You can install 2 but there really is no point. Think about it. Camber is adjusted by changing the angle of the suspension. The bottom bolt should stay stable while you change the angle of the top bolt. The bottom bolt is there for added bracing of the mount to the brake hub.
Old May 3, 2004
FattyMcJ's Avatar
Addicted to the Twisties!
Whoops....I have the camber bolt on the bottom....
Oh well, no big deal, it really doesn't serve a purpose anyway, lol.
Old May 3, 2004
robbclark1's Avatar
Old May 4, 2004
MrWong's Avatar
Bushido
So if there is a bottom bolt installed then there will be less stability, more chance for the car to go out of alignment. Esp. during autocrossing or track racing.
Old May 4, 2004
robbclark1's Avatar
No.
It is just more practical to put it on the top one and that is what the instructions say. I really don't think it matters what hole you put it in, but think about your geometry. Look at the picture I posted. If you change the alignment by using the top bolt the pivot point is at the bottom. If you change the bottom bolt, the pivot point is in the middle. The top of the brake hub where the bolt attaches to will slide in and out, thus following a similar parallel path as the strut. If you change the bottom bolt, that parallel path is shifted.
It really isn't that big of a deal to use either bolt, the same conclusion can be reached, but it is ideal to use the top bolt to get the most effectiveness out of the camber kit and your suspension.
Old May 4, 2004
MrWong's Avatar
Bushido
I get it now, thanks.
Old May 4, 2004
FattyMcJ's Avatar
SON OF A ***** !!!
Thanks man. Guess what I'll be doin' when I get my whip back... But first the body shop has to GIVE it back...damn SUV's wreckin' the *** end of my vic
Old May 4, 2004
robbclark1's Avatar
that sucks....should be an easy swap if you have the old bolt. Take the bottom bolt out, put the stock in, and swap the top.
Old May 4, 2004
MrWong's Avatar
Bushido
Just to clarify, if a shop did replace both the bottom and top bolts. Are they swapable ? (ie replace the bottom bolt with the stock bolt and then take the bolt that was taken out from the bottom and replace the top bolt.)
Old May 4, 2004
robbclark1's Avatar
they are the same bolt.
Old May 4, 2004
FattyMcJ's Avatar
Good, 'cause I don't know if I still have the stock bottom bolt...
Old May 4, 2004
MrWong's Avatar
Bushido
Has anyone had any problems with the top bolt breaking ? Not the stock one, but a aftermarket camber bolt.
Makeice3498
Jul 2, 2015 11:13 AM
ernhole1
Dec 6, 2001 12:05 PM
speed werx
Nov 27, 2001 08:52 AM
andylao
Nov 9, 2001 07:36 PM
JeffSpeed21
Bolt-on Engine Performance
Nov 4, 2001 12:33 PM
