Squeaky Eibach springs... i think
Old Apr 26, 2004
playa6tnine's Avatar
playa6tnine is an unknown quantity at this point
Question Squeaky Eibach springs... i think
i recently had eibach sportlines installed on my car, 1.7" drop. i dunno whut it is, but everytime i'm driving t low sppeds like in the nieghborhood or something, i hear this noticable squeaking noise coming from the reaer springs/shocks.
i dont know whut it is?? is it the springs, or is it the shocks? how do i fix it? when i go up the driveway or anything all u hear is this loud speak when the suspension pushes.
any one know what might be causing this?
Old Apr 26, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
Springs installed incorrectly maybe?
Old Apr 26, 2004
nivenmk1's Avatar
nivenmk1 is an unknown quantity at this point
I was reading a DIY from somewhere when I was learning about Koni shock installations... They were installing springs at the same time, and I remember there being an indentation on one of the bottom mounts/holders that was designed for the end of the spring to sit down in. They said if the end of the spring it touching any metal along the flat face of it (the place where it was "cut" from the metal used to make the spring) it would squeak. I'll see if I can dig up a link for ya but I think that might help your problem.
Old Apr 27, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
yea check ur springs....it might not be sitting in right...u know whati mean...my rear eibach are not sitting that lil dip that its suppose to be in. so it makes noise when i go slowly over bumps
Old Apr 27, 2004
biff's Avatar
biff is an unknown quantity at this point
You need some bushings or some damn thing like that. I had the Pro line put in and every time i go back to him he asks me if there squeeking yet.
not sure what bushings he was talking about
Old Apr 27, 2004
nivenmk1's Avatar
Yeah, forgot to mention that, there are spring pads that you can put on the upper and lower spring mounts that should cut out squeaking. They wear out after a good 50,000 miles or so, but work great untill then. Another thing you can do is use some thick tubing and cover the entire area of the spring where it contacts the mounts.
Old Apr 27, 2004
Cocky's Avatar
Cocky guys kick ass!
i have Eibach Sportline, never any type of problem at all. check to see they're installed correctly.
Old Apr 27, 2004
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
got eibach sportlines too... only sound i hear is the scraping of my car cuz i got a system in the back
Old Apr 27, 2004
DestnationUnkwn's Avatar
DestnationUnkwn is an unknown quantity at this point
Theres a TSB out for that.
Old Apr 27, 2004
tfnaaf's Avatar
BLDNPSI Mod
they must be installed improperly, mine have never made a noise
Mad Dog Tannen
Oct 19, 2016 08:12 PM
speedlever
Sep 24, 2015 07:18 PM
Viczhou
Sep 2, 2015 07:55 PM
Shadow277
Aug 31, 2015 12:30 PM
cukaracha
Aug 29, 2015 05:27 PM
