'02 top mt to '01
Old Apr 22, 2004
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
'02 top mt to '01
Anyone knows what parts is/are needed for the strut top mounts to convert the '02 strut to a '01. Have searched the forum and someone mentioned about needing only the '01 top mount bearing. Will just getting the top mount bearing be sufficient ? Will it fit nicely with the '02 upper spring holding plate and the top mount(with the 3 studs) ?
Old Apr 22, 2004
robbclark1's Avatar
Retired suspension supermod.
http://www.7thgencivic.com/forums/sh...ighlight=mount
you have two choices it looks like. Buy the mounts/bearings and slap them on the teins or take apart your stock suspension and use the 02 mount with an 01 bearing.
Old Apr 22, 2004
GaryC17's Avatar
So I believe they will fit very well together. So can I say the only difference from a '02 and '01 strut is the top mount BEARING and nothing else ? I am only referring to the top mounting portion and not the strut diameter or the strut holes below which could be 14mm or 16mm. Will there be a reduction in ride height after the swap ?
UltraHDGames
Jun 8, 2016 05:16 PM
Munzy
21
Oct 7, 2015 07:48 AM
Raiool
Oct 1, 2015 10:42 AM
raymondxcho
Sep 29, 2015 09:00 PM
carid
Sep 28, 2015 10:13 AM
