Eibach Front & Rear Sway
Old Apr 15, 2004
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
I just purchase the kit but I have a 2001 LX what else do i need? in order to install this kit.
And have anyone installed them... How r they... Hope they really make a difference....
thanks for any advice.
Old Apr 15, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
Eibach I think has an install kit for you also.
Old Apr 15, 2004
jdm_bb's Avatar
o it does.... so it comes with all the hardware? like endlink and bracket
hopefully it's gonna make a big difference because i get this because i want to do better on the track.
Old Apr 15, 2004
Civictuner04's Avatar
Civictuner04 is an unknown quantity at this point
Dude, u shouldve searched a little before puchasing. I hav a 2001 lx also. Our car does not come with a rear sway bar stock, which means it does not hav the mounting brackets to mount the bar. U need to buy a Progress adapter kit just to be able to install the rear sway bar, http://www.robearracing.com/pd_progr...ar_adapter.cfm . So u will need to install that first.
Also, if the eibach kit doesnt come with one, u will need a lower rear tie bar cus the rear sway bar adds extra pressure to ur rear suspension so u need the tie bar to keep everything together. U should also look into gettin a upper front strut bar. That will give u an even better handling feel and will help to offset the bigger front sway bar.
Old Apr 16, 2004
bobbyd's Avatar
I am pretty sure that Eibach has all the nessassary hardware to install it without buying the Progress kit. I know Eibach makes one cause I called them to see about replacing my rear end links with Eibachs and the rep. told me the kit just comes with OEM endlinks so I would not be upgrading.
Old Apr 16, 2004
obguam's Avatar
obguam is an unknown quantity at this point
Last I heard only progress makes the adapter kit for civics that don't have rear sway bar. If I'm wrong and Eibach has adapter too, my bad and please let me know as I need one.
Old Apr 17, 2004
jdm_bb's Avatar
I have the lower tie bar already and front struts i have it already....
So what kind of parts do i need in order to get this install?
And the eibach kit doesn't come wif the hardware......
any help would be neccessaire...... thank you
Old Apr 17, 2004
civicvtec1ps's Avatar
Search and Learn
2001 LX does not come with rear Sway bar.
You need to buy Stock Endlinks or Aftermarket endlinks to put rear sway bar.
You will also have to redrill couple holes(For the Sway bar Bushings) in order to install Eibach Rear sway bar.
25mm front and 23mm rear.
I don't see why you bought Eibach Front sway bar.
They are almost identical as Stock Front sway bar, Which is 25.4mm.
Eibach sways are hollow and although lighter, won't have the stiffness of the same size solid bar.
Old Apr 18, 2004
jdm_bb's Avatar
i got it for a gift that's why.....
Old Apr 20, 2004
orso's Avatar
orso is an unknown quantity at this point
i am looking into the eibach sway's for the simple reason that it is a complete kit and everything is going to work properly the first time. will not have to worry about the exhaust hitting, etc.. they make great products so i don't see why they would be bad. paired with eibach springs i think the car would handle awesome.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Jeffdp
Aug 5, 2015 11:38 AM
Firefly
Nov 28, 2001 06:13 PM
PimpBot5000
Nov 26, 2001 07:15 PM
andylao
Nov 9, 2001 07:36 PM
