tien flexs and jic
Old Apr 10, 2004
7gen03's Avatar
7gen03 is an unknown quantity at this point
tien flexs and jic
Looking for a deller for a set of either jic or tien flexs for 03 coupe
thanks
Old Apr 10, 2004
PunkingCivic's Avatar
I need TP for my bunghole
www.robearracing.com
www.dezod.com
Old Apr 10, 2004
robbclark1's Avatar
Retired suspension supermod.
contact nick at www.dmsperformance.com for JIC
or www.speedwerx.com for JIC
Old Apr 11, 2004
VTECTypeR's Avatar
With the tein flex do you need to buy a 01 civic upper mount or something because I have a 02
Old Apr 11, 2004
SlammedBlueEM2's Avatar
All Eyes On Z
Flex comes with it's own uppermount. For $1500, it better.
Old Apr 11, 2004
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
they don't have flex for our cars yet do they?
Old Apr 11, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
EP3, just drill a hole in the hood support to fit the adjustment ****.
From what I've been told by nearly everyone, Tein pillowballs are kinda loud.
Old Apr 11, 2004
§C§H§O§C§O§B§O
grease em up! would that work? oh, about the hood drilling, would getting a CF hood fix that?
Old Apr 11, 2004
7gen03's Avatar
what do mean kinda loud. are the jics quiet? Do the jic fit better then the tien flexs
Old Apr 11, 2004
7gen03's Avatar
the tien 04 catolog says the do have them for our cars 01+ and 03+ wouldnt rsx be a better fit
Old Apr 11, 2004
Jap-Euro Fusion
Its a metal on metal surface. They rub together, and Tein probably doesn't use as tight a tolerance or surface finish that isn't as smooth as Jic, Buddy Club or some of the others, so it has some wiggle room and makes noise. The JICs don't require you to drill the hood supports to get them to fit. If you consider that better fit, then I guess so. What's your main racing purpose for buying these?
Old Apr 11, 2004
7gen03's Avatar
I basicly want a fully adjustible coilover that has a good ride and possibliaty of race. I want a good riding adjustible coilover
Old Apr 12, 2004
robbclark1's Avatar
If it is only a possibility of race, get the Tein SS and save your money. Plus they won't be as hard on those rough roads. JICs aren't comfortable at all. for someone who wants adjustable coils with SOME racing, then stick with the SS. The flex and JIC are meant to be close to as race coils as you can handle on the street and are really stiff.
Old Apr 12, 2004
Jap-Euro Fusion
Yeah, JICs and Flexes aren't going to ride to well on anything but the best pavement. 560 lb springs will do that to you. Its not entirely a race system, but its pretty damn close. If all you're doing is driving, stick to something tuned for the street.
Old Apr 12, 2004
7gen03's Avatar
ok THanks you guys here is how I a thought about. I like the Jic and Flexes because they are full lentgh adjustable were as the ss are not . When yo lower the spring you lower the travel of the strut causing it to not work as well so in thought flexes anfd jic would be better. But as you haved stated and i have read they both have stiff springs so is it possible to get jic with a custom spring rate or not.
My choices are hayames, ss or flexes or jic and i dont really like the ss cause i need a new upper mount. But maybe tien is better product then hayame and there not on backorder. Price is not really an issue i just want a good coilover.
Old Apr 12, 2004
Jap-Euro Fusion
You can get custom JICs (called FLT A2 RS)... Plan on paying $400 more than standard to get them though. If all you're doing is street driving and not gung ho about driving around in what effectively becomes a streetable race car, then don't bother with stiff stuff.
Consider KWs or something.
Old Apr 12, 2004
robbclark1's Avatar
It sounds like the FLTA-1 would be a good choice for you but unfortunately, JIC doesn't make that for the EP3. You might want to consider the KWs also. you can get custom spring rates, but you will have to pay for them. Either you can preorder them with weaker spring rates or you can order and extra set of springs. Either way, it will cost ya. I personaly don't think you need the adjustability of JIC or Flex because you aren't going to be racing all that much. I still would stick with the SS or the KW V2.
GolNat
Nov 27, 2018 03:32 PM
Makeice3498
Jul 2, 2015 11:13 AM
timpan
May 18, 2015 07:06 AM
HondaLuver
South Cali
Mar 1, 2003 02:09 PM
bignutter
Sep 7, 2002 09:12 PM
