how to fix exhaust hitting sway bar?
Old Mar 13, 2004
abmerop18's Avatar
Jam out with your clam out.
my exhaust hits my sway bar alot when i make left turns. how can i fix this? i used to have a rubber tubing around the sway bar so it didnt make any noise and it worked, but it used to always slide away because i had it on with zip ties. anyone got any suggestions besides getting the exhaust worked on? thanks for the help.
Old Mar 13, 2004
orso's Avatar
orso is an unknown quantity at this point
tie the exhaust back. put something around it to keep it from moving.
Old Mar 13, 2004
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
I guess you could always glue the rubber piece to the sway bar... kind of ghetto, but it's not like anyone'll see it
Old Mar 13, 2004
abmerop18's Avatar
do you think the glue will hold it and not wear off from the exhaust rubbing against it? should i use super glue? ill do that if it will work.
Old Mar 13, 2004
You need to put some thermal wrap around it. That won't fall off and should provide enough cushion.
Old Mar 13, 2004
abmerop18's Avatar
thermal wrap on the exhaust or sway bar? how much would i put on and how is it applied?
Old Mar 13, 2004
AznSaint's Avatar
AznSaint is an unknown quantity at this point
gearbox meant, put it on the sway bar
Old Mar 13, 2004
Thanks. Yeah it's basically the wrap people put around the header. So it can take the heat from the exhaust pipe. If you put a few layers, it should dampen the rattle.
Old Mar 14, 2004
AznSaint's Avatar
if you dont have a custom midpipe and was looking to getting one.... get one that'll go around the sway bar.
i have a custom mid pipe with a magnaflow exhaust. made it go around the 19mm rear sway bar.... have a lot of clearance still.
Old Mar 14, 2004
abmerop18's Avatar
mine is a custom catback but it still hits the sway bar
Old Mar 14, 2004
civicvtec1ps's Avatar
Search and Learn
Get re-done.
Just go to muffler shop and let them bend exhaust pipe.
Should be 5 mins fix.
Old Mar 14, 2004
dragin's Avatar
dragin will become famous soon enoughdragin will become famous soon enough
what you can try is go get some more exhaust bushings from honda there like a dollar. and use them to keep the exhaust put. youll need to change them ever so often since they streatch out more due to the heavier exhaust. thats what i ended up doing and it works great for me
Old Mar 15, 2004
BlueRevs's Avatar
BlueRevs is an unknown quantity at this point
i use the thermal heat tape wrap, works great. put it on there about 7 months ago and it hasn't budged, but i wraped mine around on the exhaust not the sway bar.
Old Mar 15, 2004
abmerop18's Avatar
problem fixed, well-kinda. i went to the hardware store and puchased a thick piece of rubber tubing that was the exact length of the sway bar in that section. the tubing fits perfect in that section and doesnt move around anymore, but i still used 4 zipties to secure it on. it doesnt make any noise anymore, so im happy.
Old Mar 15, 2004
dragin's Avatar
ghetto fabolus!!!
Old Mar 15, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
i had this shop heat up the pipe, and kinda pinch it a little for a little extra clearance
Old Mar 25, 2004
82801BA's Avatar
82801BA is an unknown quantity at this point
I wonder why ppl are having problem on exhaust hitting sway bar on left turns...I changed my sway bar and doesn't hit anything...Is that because of the size of the bar?
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
Firefly
Nov 28, 2001 06:13 PM
jessepimpride
Nov 13, 2001 05:59 PM
