Best Springs for stock shocks?
Old Mar 10, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
Ok, I have searhed and searched and i want to hear from the guys who have actually been running drop springs with stock struts for a while now.
What spring are you running and how do you like them on the stock struts/shocks?
The ones I have in mind are:
Eibach Prokit
Tein S. tech
Tein H.
Eibach Sportlines
H&R
More susggestion are welcome.
p.s. I do not want a full coil over system or sleeved coilovers at this time, thanks for the help.
Old Mar 10, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
Tiens are designed to work with stock shocks
Old Mar 10, 2004
streetglower's Avatar
I would have to say eibach, either the prokit or the sportlines. I had mine on there for about 4 months, and when I took my stock shocks off, they felt brand new.
Old Mar 10, 2004
bobbyd's Avatar
What did you have though? Prokit or Sportlines? What was the spring rate on the srping..if you looked?
thanks
Old Mar 10, 2004
flotsamm's Avatar
Eibach Prokit is designed for stock struts/shocks. I think H&R's are also. When I had my stock struts/shocks with my Sportlines, the ride was good but bouncy except on smooth roads.
Keep in mind that our generation Civic is bouncy by nature. Watch any stock Civic ride down the highway and it'll be bouncing more then most other cars.
Old Mar 10, 2004
bobbyd's Avatar
I am leaning toward three as of right now..in no particular order:
1) Prokit
2) H&R
3) Tein High Tech
I can not find one single person with the High Techs though!
Thanks for the info. guys...keep it coming.
Old Mar 10, 2004
Zzyzx's Avatar
Autocross Junky
If you are looking for a really well handling suspension set up heres what I have.
1. Eibach springs (not sure if they were the pro kit or sportlines, they were on the car when I bought it new)
2. 03+ Civic Ex front anti-roll bar (16mm vs my 01s 25.4mm)
3. RSX 19mm rear anti-roll bar.
the car is Very fun to drive and very tossable, and because of the 19mm rear bar rather then a 22mm rear bar, the car is still stable in High speed corners. Its even more fun when I have My Falken Azenis on
only thing I'm missing now is Shocks.
Old Mar 10, 2004
I am going to go to a junk yard and see if I can find a roll bar from a wrecked rsx, would it be the type s or just base rsx?
Old Mar 10, 2004
SlammedBlueEM2's Avatar
All Eyes On Z
You could get that bar as cheap as $50. No need to go to the junkyard for that.
All RSXs have 19mm rear bars.
Old Mar 10, 2004
Where can I get it for $50 besides looking in a junkyard?
Old Mar 10, 2004
flotsamm's Avatar
If theyre black springs, then you have the Prokit. If red, then Sportlines.
Old Mar 10, 2004
All Eyes On Z
Try clubrsx.com?
Honda-tech?
Or even this site?
Or even the dealer? I think some dealerships were letting them go for cheap, too.
Old Mar 12, 2004
slystad810's Avatar
Hey whats up man? Long time eh? Can't wait til summer!
My Goldlines are still going strong on stockies, and I got a steal on the GB for $99.
Old Mar 12, 2004
Zzyzx's Avatar
Autocross Junky
Then its the pro kit.
Old Mar 18, 2004
ImPulse's Avatar
bump... H&R or Prokit?
Old Mar 18, 2004
bobbyd's Avatar
I actually think I decided on the Tein H. Tech springs.
Old Mar 19, 2004
DestnationUnkwn's Avatar
DestnationUnkwn is an unknown quantity at this point
I have the Pro-Kit and it works fine.
Old Mar 19, 2004
Theeyo's Avatar
Theeyo is an unknown quantity at this point
i dont have any of those, but i do have the Nuespeed racing springs (2.5" drop) on my stock shocks...its been on there for a lil bit over a year now and my shocks are dead
Old Mar 19, 2004
02VicLx's Avatar
02VicLx is an unknown quantity at this point
i have sportlines and my shocks are fine. i would like more of a drop so i might cut my springs and ride my shocks out, than replace them. i dunno yet.....
Old Mar 19, 2004
bobbyd's Avatar
Cutting your springs is dumb and dangerous!
Old Mar 19, 2004
robbclark1's Avatar
Retired suspension supermod.
some aftermarket springs you can cut a dead coil off of to make it lower. It won't hurt the spring. Neuspeed recommends it for some of their springs.
Old Mar 20, 2004
02VicLx's Avatar
i dont understand how it is dumb and dangerous? as far as i know all springs have dead coils that you can cut. dumb? only if you cut it without jacking your car up and taking the tire off. dangerous? cutting the dead coils wont effect anything other than ride height.
Old Mar 20, 2004
flotsamm's Avatar
Progressive rate springs have dead coils that can be cut off in most cases. If you cut to many coils off, there wont be enough preload to keep the spring in place. This can be dangerous. With linear springs(like stock) that dont have dead coils, you have to be even more careful since they typically have less preload to play with when cutting. Unless you certain about the amount of coils to cut, I wouldnt recommend cutting anything.
Also, some springs are sensitive to heat, so you must make sure that your using the proper cutting method and not heat up the spring.
Old Mar 21, 2004
Cocky's Avatar
Cocky guys kick ass!
Sportline, i love mine. much smoother than stock springs.
Old Mar 22, 2004
EXspeed's Avatar
EXspeed is an unknown quantity at this point
I'm considering the spring switch too, and am wondering about the stock spring issue too. The konis are a little steep. If stock shocks can hold up I think I go with the teins. Still don't quite get the deal with the coil over sleeves.
Old Mar 22, 2004
bobbyd's Avatar
What don't yopu get with the sleeves?
Old Mar 22, 2004
EXspeed's Avatar
Why are they so much cheaper? How bad do they suck?
Old Mar 22, 2004
robbclark1's Avatar
read the suspension FAQ in my sig. Sleeves are adjustable springs. They can give a bouncy ride because you are on stock shocks. If you get sleeves then GC of Skunk2 are the ones to get but I would get Konis to go with them. Full coils are an easier swap.
Old Mar 22, 2004
EXspeed's Avatar
I think I'm going with the Tein s-techs, everyone I've talked to said they would work fine with stock shocks. And I found them alot cheaper at revhighonline.com
Old Mar 23, 2004
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
bobbyd - are you gonna be putting larger wheels on your car? if so, i would go with the s techs over the h techs because they will be slightly lower. i think that the h techs are made for luxury cars, not sport compact??? does anyone know if this is the case?
