question please help??
Old Mar 3, 2004
buddyclubcivic's Avatar
buddyclubcivic is an unknown quantity at this point
Question question please help??
does anyone know will the RSX suspension (coilover springs and shocks) fits into our civic?? mine is a 2001 civic coupe. any information will help. thanks alot.
Old Mar 3, 2004
civicvtec1ps's Avatar
Search and Learn
Yes, It is possible.
You would need new tie rod from rsx and make bigger holes for front camber bolts.
2001 civic uses 14mm and RSX uses 16mm.
Old Mar 3, 2004
Zzyzx's Avatar
Autocross Junky
The RSX springs are different lengths then the civic (Non Si) so the ride height will be off.
Old Mar 3, 2004
Thanks for the information. A friend of mine is selling a set of coilover for a RSX so I am just wondering would it fit perfectly into my civic or not.
Old Mar 3, 2004
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
Not only that, you got to bore your knuckle arm holes larger to fit the bolts too !!! You could use the smaller 14mm bolt though, but anytime your shocks might just move out of position.
Tedverseti
Apr 23, 2020 01:45 PM
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
