RSX Sway Bar - Squeek after install!
Old Mar 2, 2004
ELaudio's Avatar
ELaudio is an unknown quantity at this point
I've searched rigorously through the forum and couldn't find any posts about my problem, so I'm hoping someone can help me. I installed an RSX Type-S sway bar over the weekend. Install went fine, no problems other than the pain in the *** it was to remove the end-link bolts!
At low speeds when cornering, I hear major squeeking coming from the rear end. Has anyone else had this problem? My only thought is that it may be caused by over-torqued end-link bolts. I couldn't fit my torque-wrench in there, so I torqued them up really well - maybe too well? I also read on another post that installing the bar backwards may cause squeeking. Comparing the pictures from the DIY to my car I don't think this is the case - but is it possible that I may have done this, i.e.: will the bar fit if installed backwards?
Any help would be greatly appreciated!
ELaudio
Old Mar 2, 2004
reytito's Avatar
i have the same problem. i do notice that the creaking goes away after a bit of driving. i have yet to get under there and wd-40 the bushings. i'm guessing, and hoping, that thats all i needa do. i would recheck your endlink bolt for tightness, lube your bushings, and see if that'll do the trick. if not...i dunno...ask a suspension god...boiler, robbclark, vnlilman, etc. post if you solve the problem though!
Old Mar 2, 2004
MIT's Avatar
MIT
MIT is an unknown quantity at this point
hows that goin to happen if over-torqued end-link bolts? i just installed that rsx sway bar last weekend, i torqued end-link bolts as tight as possible....nothin happen yet.
Old Mar 3, 2004
ELaudio's Avatar
The creaking has lessened a bit. I'm installing coilovers in about a month, I'll get in there and grease all the bushings. I just wanted to make sure I didn't do anything wrong (over-torque).
Reytito - I'd avoid using WD-40 on the bushings. You're better off using grease. WD-40 washes away and it actually disolves grease.
Old Mar 3, 2004
VNlilMAN's Avatar
The Standard One
ya try greasing the bushings
Old Mar 3, 2004
reytito's Avatar
any specific kind/brand of grease recommended?
Old Mar 4, 2004
PlasmaGT's Avatar
My Baby Daddy
PlasmaGT is on a distinguished road
Do you have the stock (rubber) bushings or polyurethane? If they're stock they shouldn't be squeeking.
Old Mar 4, 2004
VNlilMAN's Avatar
The Standard One
The stock rubber shouldnt but sometimes when you mess with it it does... I had that problem when I installed my camber kit wrong...
White lithium grease should do the trick.. sorry not sure where to find it tho
Old Mar 4, 2004
PlasmaGT's Avatar
My Baby Daddy
My Energy Suspensions bushings came with a little tube of "prelube". I ordered a tub of it through the local Car Parts store. It's made for bushings. Otherwise white lithium grease will work.
Old Mar 6, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
I had no squeeks... but I bought the RSX bushings..........
Old Mar 6, 2004
Vteced02civic's Avatar
Vteced02civic is an unknown quantity at this point
Does anyone have a pic of an rsx sway bar after instal. I searched every where and cant find one. IF so can someone please post!!!
Old Mar 6, 2004
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
http://www.xenja.com/7thgencivic_RSX..._DIY/index.htm
Old Mar 6, 2004
greeot's Avatar
greeot is an unknown quantity at this point
^^nice dyi.
Old Mar 6, 2004
I followed the same DIY
Old Mar 6, 2004
No i saw them pics, but i need a pic with the suspension fully compressed and both wheels on the ground.
Old Mar 7, 2004
ELaudio's Avatar
I took a peek under there yesterday and realized the problem. I tightened down the bushings BEFORE tightening the end-link bolts. So, the sway bar's ends are ligning up perpendicular to the endlink bolts. I'm going to jack up my car again today and see if I can fix it...
Old Mar 7, 2004
Perpendicular? Then how were you able to tighten the end links and the bar? I did it the same way you describe, bushings 1st, but I did have the bar hanging on the end links though when the bushings were screwed down, but not completely.
Old Mar 8, 2004
ELaudio's Avatar
I unbolted everything, greased everything, still squeeking like a ****. Only when I'm turning left, at parking-lot speeds on tight corners. Ugh. Not sure what else to do!
Old Mar 8, 2004
reytito's Avatar
hmm....thats when mine squeaks too...
Old Mar 9, 2004
ELaudio's Avatar
Well, I'm hoping things will get better once I install my Hayames in a few weeks.
Old Mar 11, 2004
ELaudio's Avatar
UPDATE: I determined that my noise was being caused by the exaust piping hitting the sway bar. I used to have a Magnaflow cat back, sold it and went back stock. When I had the Magnaflow, I slightly modified my exhaust hangers to prevent rubbing with the bumper. This has left me with hangers that are a tad too long - causing a rattle/creak-type of noise when I'm turning hard at low speeds.
I'm going to modify my hangers this weekend and see if that fixes the problem. (I also noticed that someone posted with a similar problem)...
EL
Old Mar 11, 2004
reytito's Avatar
hmm interesting.. i have magnaflow right now. but the noise doesn't sound like exhaust hitting the sway...plus it sounds like it comes from the driver side rear....
Old Mar 11, 2004
ELaudio's Avatar
My noise is coming from the passenger-side rear. It's gotten more frequent and after listening closely, it does sound like vibrating metal hitting the sway bar. Wiggling my tailpipe made me realize that I have very VERY little clearance between the swaybar and the exhaust.
Misfit2613
Jul 30, 2015 09:49 AM
fordover
Jul 11, 2015 09:10 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
