Cvc wheel problem
Cvc wheel problem
i was involve in car accident this weekend and i spun out of control and hit a wall...now the thing is that my wheel moves like it was broken and so does the stearing wheel...
i looked underneath and i seen that my lower control arm was bent and my front anti-say bar
is also broken...
i was wondering if i replaced those parts would my car drive normal once again...because if i
take it to the dealer there goin to charge me an arm and a leg....
or what do you guys suggest???????????
If the unibody is damaged, it may never drive properly again. If its a replaceable part like the LCA and swaybar end then you might get away with it. If it was me, I'd reaplce the LCA and fix the swaybar and then go from there. Either way those have to be fixed... good luck.
Its a celebration bitches!
LCA, lower control arm....
once a car is in a accedent, the car will never be the same... if i where you i would just upgrade everything under there, or just replace it with stock... and get a alignment
Yeah you should really get a mechanic to at least look at and see what damage has really been done.
You would first want to replace the LCA and the Sway Bar, and get an alignment, check the rim as well to make sure its not bent.
Go from there.
Good Luck
Crashoveride
Go from there.
Good Luck
Crashoveride
honda200192
May 31, 2015 05:57 PM
cmart1209
May 29, 2015 04:52 AM
jakeconnor
May 5, 2015 07:30 AM
