Eibach Pro Street
Old Feb 20, 2004
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
Eibach Pro Street
Anyone knows if the Eiback Pro-street True Coilover is out ? Seen pictures of it in magazines but not sure if its out. According to Eibach website, it is in development for the Civic Si. If it fits the Si, will it fit the EM coupes/ sedan ?
Old Feb 20, 2004
robbclark1's Avatar
Retired suspension supermod.
No, as far as I know, it is not out yet.
Old Feb 20, 2004
HondaLuver's Avatar
Its a celebration bitches!
if it was out, it would fit the coupe, you would have to make some minor changes with the front camber because the camber bolts are bigger front what im told.
Old Feb 20, 2004
GaryC17's Avatar
You mentioned the front camber bolt sizes for the Civic EM and Civic Si are different in sizes. If the Si uses a larger bolt, will it be safe to use a smaller bolt to secure a Civic Si designed shock absorber(which has a larger bolt hole) to the knuckle arm of a EM Coupe ? Wouldn't the shock move out of position ?
Old Feb 20, 2004
GaryC17's Avatar
Will the tie rod ends of the EM fit into the Civic Si designed linkage arm on the shock absorber ?
Mad Dog Tannen
Oct 19, 2016 08:12 PM
rovafa2002
Sep 28, 2015 06:57 PM
Skunkone
Sep 24, 2015 04:38 PM
krazykoncepts
Sep 8, 2015 09:02 PM
Viczhou
Sep 2, 2015 07:55 PM
