Ingalls rear kit on...let the squeeks begin...
Old Feb 3, 2004
fo50rd's Avatar
fo50rd is an unknown quantity at this point
Angry Ingalls rear kit on...let the squeeks begin...
I just finished installing an Ingalls rear camber kit on my 02 sedan, just a week or so after installing my Pro Kit. (Yes, it needed one...VERY visible lean in) MAN, all of the sudden, squeeks from hell! All from the passenger rear side. I took everything apart today and put Never seize and white lithium grease everywhere...to no avial. I also ended up stripping out one of the bolts on the new camber arm that screws up like into the trunk area. Jeez, this sux! Sounds like dry polyurathane bushings rubbing together in the trunk! Anyone have a suggestion?
Old Feb 3, 2004
Mr.Modify's Avatar
i think alot of cars squeak a lil when lowered cause i know mine does when i'm parking in my yard but it doesn't bother me.
Old Feb 3, 2004
Crackhead79's Avatar
Put plastic washer between everything that touches the body, it will stop the sqeaks. If it doesn't it not coming from there-
Old Feb 3, 2004
streetglower's Avatar
damn you need a rear camber on a prokit, I have the sportline and all I needed was the front camber kit.
Old Feb 3, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
Re: Ingalls rear kit on...let the squeeks begin...
Were you using crescent wrench? don't use those fuukin things! but you can use them as a hammer!
Old Feb 3, 2004
Mr.Modify's Avatar
damm you need a front camber kit? wow i didn't think anyone got a front camber kit (seriously though ?).
Old Feb 3, 2004
the reason why I need a front camber kit is because I hit something and it knocked my alignment way out of spec and they are out right now by about -1.3 degrees on one side and -1.5 degrees on the other side. if I wouldnt of hit something they would of been fine.
Old Feb 4, 2004
fo50rd's Avatar
No crescent wrenches here. All bolts torqued to spec. I may try the plastic washer thing on the two bolts on the inside of the camber arm...one of the ones I stripped. Doesn't make much noise bouncing up and down on the car when stopped, but when rolling into the driveway and into the garage...it sounds like my greatgrandma's old rocking chair!
Old Feb 4, 2004
fo50rd's Avatar
Maybe my car is an exception, but just after installing my wheels and tires the rear wheels were noticably leaning inward. After the springs...it looked like a old VW Beetle or something. Straight up level, now, slightly rubs the fender lip. Had to put a tad of camber on it and it works great...just the freakin squeeking on that one side!
Old Feb 5, 2004
orso's Avatar
orso is an unknown quantity at this point
i have the ingalls kit and mine does the same thing. i think the actual problem is with the bolt that conects the kit to the rear spindel. the kit comes with a nut not welded on to the kit. the factory arm as the nut welded on to prevent the nut from sliding up and down. just my thoughts
Old Feb 6, 2004
VNlilMAN's Avatar
The Standard One
did all of you DIY or have a shop do it? I get sounds too but its with my stock camber. i took it off but ended up putting it back. I think i know what i did wrong, i'll let you guys know once i install my spc.
Old Feb 6, 2004
fo50rd's Avatar
DIY here.
Old Feb 6, 2004
fo50rd's Avatar
VNlilMAN, are you sure it's your stock camber making the noise? I know some folks have gotten squeeks and noises from their coil springs being butted up against the stopper. I always place mine a sideways finger back off the stopper...if that makes any sense.
Old Feb 6, 2004
VNlilMAN's Avatar
The Standard One
i started gettings squeeks after i was messing with the camber kit
since the squeeks i have changed suspensions and the squeek/clanking is still the same coming from the same place.
I think mines not tight enough AND i was reading the instructions and you have to tighten the nut on the arm while the car is on the ground, not when its raised. something about it putting a preload on the bushings when its raised...
Old Feb 6, 2004
djmota's Avatar
This is an important step that alot of people do not do. This can cause that bushing to move and squeek. You don't have to have the car on the ground, you can preload the rear suspension with a floor jack and then tighten it down.
Old Feb 12, 2004
orso's Avatar
well i did preload mine. i don't think that was it. maybe it is the spring perch. guess i will check that tomorrow.
Old Feb 13, 2004
VNlilMAN's Avatar
The Standard One
are you guys greasing it properly and at the right place?
Old Feb 13, 2004
HondaLuver's Avatar
Its a celebration bitches!
i always greasy my stuff and put it in the right places... hehe
Old Feb 13, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Anti-Sieze ownz j00!!!!!!!!!!
Ingalls on the left, stock on the right. I don't hear a darn thing.
Old Feb 14, 2004
orso's Avatar
hey boilermaker you have the urethane bushing right. well i have the rubber bushing from ingalls and mine still does it.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
j-chest
Jul 31, 2015 01:18 PM
chrisjackson321
Jul 12, 2015 03:00 PM
