DIY: Hayame Rear - Front not complete
Old Jan 22, 2004
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
Aite guys, I'm new at this stuff, but i'll give it a shot.
THis is a Hayame DIY for those of you who plan to get or have gotten the Hayame coilover system, and since most of you know what the hell is going on neway, this one won't be that in depth, but will note general problems and small issues that you may or may not run into.
here we go!
--- here's my car with stock struts and ground controls ---
this is the rear of the car, the next following steps will be for the rear assembly install only
Old Jan 22, 2004
§C§H§O§C§O§B§O
Of course, this is all done after your car is lifted and wheels off
--- Next is the shot of the first bolt that I loosened ---
this one was pretty hard for me to get off...after you unscrew it for a while, you notice it stops comming out, so then you pull on the bolt, and it should come out. If it jammed like mine did, you have to swirve it around and try to wedge it out.
Old Jan 22, 2004
ImPulse's Avatar
nice, all i need are the coilovers! :-p I will wait for the rest to come up
Old Jan 22, 2004
§C§H§O§C§O§B§O
Ok, now you go into your trunk, scoot your rear seats in, and pull up the corner carpeting to expose the strut mounting points. Unbolt the 2 bolts with a 14 mm deep socket with wrench, these were a b*tch for me when i didn't have the deep socket head, the shallow one won't work cause the bolt is too long for it
Old Jan 22, 2004
§C§H§O§C§O§B§O
after you unbolt those, go back out under the car, and push the stock strut out and wedge the whole assembly off, and wedge the hayame assembly in the stock position. I pretuned the hayame's before I put them in so they would all be at the same height. you can do it for what ever ride heigt you like.
Old Jan 22, 2004
§C§H§O§C§O§B§O
TO finish it off, use the lugs provided by hayame to secure the 2 in-car mounting points, and then put the BIG bolt back through the bottom end of the strut connected to chassy
Here's a pic of the finished product
Old Jan 22, 2004
§C§H§O§C§O§B§O
and another
Old Jan 22, 2004
§C§H§O§C§O§B§O
do the same for the other side...
now your rear suspension is complete...
more to come after i finish installing the front
Old Jan 22, 2004
Fletchman04's Avatar
Fletchman04 is on a distinguished road
good pix but what are all those random wires in you back seat?? you've either got a nice system being installed or you like selling wire door to door.
Old Jan 22, 2004
§C§H§O§C§O§B§O
lol...i have a system...but i haven't arranged my wires yet ^_^
2 alpine amps powering diamond audio m3 components and alpine 6x9 rears, and another amp powering my alpine 12" woofer
Old Jan 22, 2004
JCiv03's Avatar
Cool diy! this is nice for people like me who doesnt know how to do suspension.
Old Jan 22, 2004
ImPulse's Avatar
PM me when everything is done and let me know how u like em!
Old Jan 23, 2004
§C§H§O§C§O§B§O
^ so far with the rear...all i gotta say is WOW!! that shi*t rides NICE!!!!!! no regrets...can't wait to get the fronts on... i'll keep everyone posted
Old Jan 23, 2004
AZNRACR's Avatar
I want to get a set, where did you get them from and how much?
Mike
Old Jan 23, 2004
§C§H§O§C§O§B§O
PM dezod, excellent service from them...also if you check in the group buy section, robearacing has a GB for them.
Old Jan 23, 2004
slicksivik's Avatar
damn that looks easy. 3 bolts and ur done! i wish i would do that but i would want someone else to help incase i fudge up like i probalby would haha. in the 03 u gotta make the hole bigger so i kno i'd mess that up.
Old Jan 23, 2004
slicksivik's Avatar
im also scared to touch the car once its up on jacks, last time i did that, i closed the door and the whole car shifted and kabooommm right on the floor.
Old Jan 23, 2004
reytito's Avatar
yeah that sounds..easy. alittle too easy
Old Jan 23, 2004
ImPulse's Avatar
only you man... Haha
Old Jan 23, 2004
KeNsHiN's Avatar
LEVA
did you put that 3rd locking ring to work after?
Old Jan 23, 2004
§C§H§O§C§O§B§O
yes i did...it adjusts the length of the strut like vinlilman said, instead of compressing the spring. Works wonders!!
Old Jan 24, 2004
tripledoublegs's Avatar
Euro-Spec
I just got my Hayames today, and I'll be installing it tomorrow. Cant't wait
Old Jan 24, 2004
AZNRACR's Avatar
Wish I could get them now, but i found a place that has them for $599 shipped everyday. So I can wait a little while
Old Jan 24, 2004
Shlomo's Avatar
Shlomo is an unknown quantity at this point
what place is that??
Old Feb 7, 2004
MeguiarsEM's Avatar
MeguiarsEM is an unknown quantity at this point
What happened to the front?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bsmiley
Apr 27, 2015 01:27 PM
zcwagon
Apr 24, 2015 05:18 PM
artychris
Nov 10, 2001 01:06 PM
