hayame question
§C§H§O§C§O§B§O
hayame question
Aite, instead of posting in that long thread, I decided to post here for the ease of those who can answer my question.
I just got the hayame's today, and on the 2 rear shocks, there was a rubber ring sitting on the top, not mounted to anything...what do i do with those? just leave them as they are? do they just serve as a barrier between the top perch and the car body?
Thanks in advance
Thanks in advance
§C§H§O§C§O§B§O
sorry robbclark, the other thread was getting WAY to crowded, next time i'll PM vnlilman personally, its just that he isn't online, and I REALLY want to get these on my car ASAP!!! ^_^ u know how it feels... neway, sorry bout that
§C§H§O§C§O§B§O
and i think i just answered my own question, there ARE there for buffering... off to the install, mods you can lock or delete this thread or whatever you chose! ^_^
The Standard One
Ya you answered your own question. They are on the stock strut assembly's as well. Good luck with the install. In case you have other problems i'll leave this open so that you can post here
HELP! i was installing these in the front and i can't get the tie rod out! haha i was using a rubber malet to hit it but it would move! any ideas? i really don't want to take any short cut that could **** up the car
Search and Learn
Originally posted by KeNsHiN
HELP! i was installing these in the front and i can't get the tie bar out! haha i was using a rubber malet to hit it but it would move! any ideas? i really don't want to take any short cut that could **** up the car
DIY
Tie bar?
The Standard One
eh you should know what he meant.. tie rod...
Thats your problem right there, your using a rubber mallot. rubber gives.. it gives alot.. try using a regular hammer. You can always rent a tie rod seperator for free at autozone but those tend to rip the tie rod boots
if you need to use more force to hammer that bolt out, a trick that will prevent the bolt from warping is to hold a thick piece of soft wood underneath the bolt. Rather than hitting the bolt directly, hammer up on the wood. This will reduce the force being put on the end of the bolt. You could also put that 17mm tie rod nut near the end of the bolt as another precaution to protect the threads.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
