After market Bushing...
Old Jan 5, 2004
KaZeLL's Avatar
KaZeLL will become famous soon enough
Post After market Bushing...
Does anyone know if they make a poly bushing set for our cars yet...01-03 ...
i took my car to pro fab to get a new clutch put in and when they dropped the sub frame
they noticed that the A arm bushings were torn...( on both sides) not only that but the front motor mount was done as well...
i bought the Oem back bushing for the A arm $35 for the two...remember I still need the front two...as for the motor mount were going to weld that bad boy up so it will never brake..
but figureing since the fronts r bad then the rest must be going as well...
Old Jan 5, 2004
Zzyzx's Avatar
Autocross Junky
Lower control arm buhsings (that A-Arm) are availible from energy suspension... cheep (about $40 for a full set for the front suspension, about $60 for the rear). There are no motor mounts availble that I am aware of.
Old Jan 5, 2004
robbclark1's Avatar
Retired suspension supermod.
there is a DIY on how to fill in your existing motor mounts with Polyurethane. It is in tech stuff. I don't think anyone will make motor mounts for the D17.
Old Jan 5, 2004
KaZeLL's Avatar
I'll do a net surch but can you tell me wheres a good place online to buy from..dont want to get ripped off ...thanks
Old Jan 5, 2004
Zzyzx's Avatar
Autocross Junky
I bought mine at a local performance shop..... a Real one catering to Race cars, motorcycles and Karts.......
Old Jan 6, 2004
abmerop18's Avatar
Jam out with your clam out.
are these the bushings you are talking about? where can you purchase them from? i dotn see a link to purchase them on the energy suspension page. how hard are these to install, how much would installation cost at a shop? thanks for the help.
Old Jan 6, 2004
robbclark1's Avatar
fronts need to be pressed out then the new ones pressed in. The rears are a pain in the ***. They are quite a bit of work. Here is a DIY
http://www.energysuspension.com/artpg1.html
you can get them online at a bunch of stores. try jegs, ptuning, etc.
PS that control arm is for a different car. Ours isn't that big.
Old Jan 6, 2004
Zzyzx's Avatar
Autocross Junky
Heres my DIY.... well not really
On the front control arms you only replace 2 bushings.... The front one was really torn up the rear wasn't. (Front = Bushing closest to hand)
Heres the rear mount
Heres the front mount
Heres the press we used to push the bushings in and out...
and hers the finished product
Oh! you can see one of my race tires in the background!!!!
I loves my race tires!
Old Jan 6, 2004
slowvic's Avatar
slowvic is an unknown quantity at this point
He sleeps with a pair of azenis rs's at night. (no offense)
Old Jan 8, 2004
opto_isolator's Avatar
Yeah, the fronts are easy - its the rears which are a beeyotch.....
solarpunk70
Apr 12, 2016 11:43 AM
Ziggy1999
Oct 15, 2015 07:56 PM
Cam Diaz
Sep 28, 2015 08:34 PM
Zedoc
Engine Swaps
Sep 12, 2015 04:27 PM
Wheela
Wheels and Tires
Sep 7, 2015 02:14 AM
