how long has it been snc eu lowered ur car..
Old Dec 22, 2003
Tojo's Avatar
=) Im Bi-Sexual <3
Tojo is an unknown quantity at this point
Question how long has it been snc eu lowered ur car..
without Alignment?
y do u think u dunt need it?
Old Dec 22, 2003
DizWikedCivic's Avatar
u seriously need to know how to type
been lower about a year now w/o a alignment
Old Dec 22, 2003
civicvtec1ps's Avatar
Search and Learn
About 3 months. Not planning to get it any soon lol.
Old Dec 22, 2003
clownprince's Avatar
Ricerus Maximus
My suspension is so f*cked there is no reason for me to get an alignment. If I feel it pulling one direction I just ****** it the other way and it's all good.
Old Dec 22, 2003
Pharoh's Avatar
Bobaganoosh!
I've had my car lowered for almost 2 years now and it's only had one allignment. No need to yet either.
Old Dec 22, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
my suggestion is to get an alignment and camber kit anytime you lower your car, that way you'll save money later on buying new tires sooner....
Old Dec 22, 2003
Pharoh's Avatar
Bobaganoosh!
^^ That's good advice. A camber kit is always a good idea however if you don't have the $$ to spare don't worry about it unless you go lower than 1.75". A 2" or lower drop will require a Camber kit. I wish I could find my slip from my original alignment when I had the springs installed. The numbers explain alot. If I can find them I'll post 'em up.
Old Dec 23, 2003
IDQcivic's Avatar
I'm telling ya, i Used to have only 1" drop with the pro-kit and I wish I would have spent the 150ish to get the camber kits, because I had to spend over 500 for new tires, no joke! When I got my new tires, I installed the camber kits and got an alignment, drove all summer and my tires look like brand new!
Old Dec 23, 2003
Vinh's Avatar
a little bit of negative camber is good for hard cornering
Old Dec 23, 2003
Zzyzx's Avatar
Autocross Junky
^^^ alot is better^^^
MMMM camber..............
seriously, if you are going for tire longevity, get one and set it to the stock settings....
If you want better handling.... get a camber kit and get as much Negitive camber you can out of it. (on the front that is, the rear will have Less)
Old Dec 23, 2003
HomerSimpson's Avatar
Mine has been lowered for alike a year now. I plan on getting an aligment when I get my new tires and camber kit in a couple weeks
Old Dec 24, 2003
tfnaaf's Avatar
BLDNPSI Mod
Been lowered close to 2 years, aligned right after the springs. checked again in like 5 weeks was still in alignment. then got my 18's. Re-checked alignment was barely out on front and rear camber. Did both kits and this was like 2 months ago.
Old Dec 24, 2003
civic4dizoor's Avatar
civic4dizoor is on a distinguished road
getting an alignment after putting springs on is a waste of money... id only get an alignment done if the car swerves when u let go of the wheel or when ur driving straight and the steering wheel isnt..
Old Dec 24, 2003
tfnaaf's Avatar
BLDNPSI Mod
:zbsflag:
Old Dec 24, 2003
Pharoh's Avatar
Bobaganoosh!
Did I say I only got the car alligned once? I should have said, once for the springs and three more times for each occasion that my feckin struts blew out! I got the '04's in it now so I haven't had any problems but I'll have to do it again in the spring when my KW's go in.
Old Jan 13, 2004
JX6's Avatar
JX6
Redline Adrenaline VP
JX6 has a spectacular aura aboutJX6 has a spectacular aura about
I have an 2001 EX Coupe and I got it lowered with tein s tech springs.
The steering wheel turns when I let go of the wheel. Is it because it isn't aligned?I cant even relax when I drive because I have to hold the steering wheel so hard....of course I am getting stronger.LOL.
Anyone have any Ideas?
BTW anyone know how low the springs settle at?
Old Jan 13, 2004
tfnaaf's Avatar
BLDNPSI Mod
If the car is sterring to one side or the other when you let go of the steering wheel here are some possible causes.
1. Tire is low on Air pressure
2. Tire is bad and is causing it to pull
3. Alignment is off and needs set
4. power steering is bad and is assisting when it shouldnt
5. Brake is dragging on one side severly
I would start with checking the air pressure and alignment. These are the most likely causes.
Good Luck
Old Jan 13, 2004
4bangin's Avatar
mine has been lowered for a year and i get it aligned everytime i switch from stock to rims and i had it done when it was first lowered, so i have had it aligned 3 times going on 4 soon.
Old Jan 13, 2004
sspem2's Avatar
em2
you NEED an aligment. this is what your tires will look like. im dropped 3 inches and now i got an aligment my tires are perfectly straight. i drive to miami, daytona, ect. for car shows and those are pretty far distances and pretty soon my tires would be bald. get an alignment. its only 100 bucks.
Old Jan 14, 2004
JX6's Avatar
JX6
Thanks for the help!
Tedverseti
Apr 23, 2020 01:45 PM
alxz310
Jul 30, 2015 12:18 PM
Kyles24
Jul 12, 2015 09:15 PM
Jul 12, 2015 11:54 AM
aultman1990
Jul 9, 2015 08:27 PM
