How do i do my own camber adjusting???
Old Dec 20, 2003
Fletchman04's Avatar
Fletchman04 is on a distinguished road
Question How do i do my own camber adjusting???
I was wondering if just eyeballing your tires to see if they are straight is good enough for adjusting the camber? I am getting new tires put on today and if i need to i can just get the shop to do it but it's gonna cost an arm and a leg for them to do it. any help would be most appreciated. Thanks!
Old Dec 20, 2003
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Actually, go to ingallseng.com
They have a camber gauge that should be pretty accurate.
Old Dec 20, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Eyeball? HaHa... like you can eyeball the difference between 1/2 a degree.
They sell camber gauges all over the place. I don't know if AutoZoo would sell it, but maybe them or Napa sells them. They're not too expensive, its just a bubble level or an indicator needle. Just make sure the car is on flat LEVEL ground when you do it, or you'll be all screwed up. Its a little bit of a pain in the *** since you have to keep jacking up and removing the tire to adjust it then putting it back on and dropping it to check it. Its only like $50 for an alignment and you only gotta do it once provided you don't hit anything... its probably worth saving the trouble.
Old Dec 20, 2003
tfnaaf's Avatar
BLDNPSI Mod
If you do this with out setting your toe , be ready for very bad tire wear! Camber is a tire wearing and handling angle, but if you dont set toe too your asking for trouble. Setting your camber with a cheap gauge is ok if your doing it at home so you can drive it to an alignment shop to have it set correctly, but i dont recomend setting it that way and not having it checked with a real alignment machine.
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
TheRiddicles
Sep 21, 2015 01:28 AM
