1.5 inch drop, do I need Camber kits?
Old Dec 14, 2003
Silverphantom's Avatar
Silverphantom is an unknown quantity at this point
I've had my car lowered with Nitto 215/35/18s for a couple years now (18,000 miles) and the wear on the tires haven't been bad but I recently found small bubbles forming on every tire. Some are on the outside and some inside but they are all near the rim. I didn't think a inch and a half drop would call for camber but I wanted to see what everyone else thought. And if I should get a kit any suggestions on brand or site.
Thanks
Old Dec 14, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
personally, i went on the safe side and got a camber kit. i have an SPC camber kit for the front and back.
im not exactly sure how much im lowered....im as low as i can go on my Tein SS if that tells you anything.
tires are f-ing expensive- might as well put a camber kit on and make them last as long as possible.
Old Dec 14, 2003
robbclark1's Avatar
Retired suspension supermod.
you never NEED a camber kit but if you want your tires to last then you should get one. Racers run with negative camber because it helps turning, but also increases tire wear.
SPC or ingalls. if you get spc get it from a member her named danscreations.
Old Dec 14, 2003
tfnaaf's Avatar
BLDNPSI Mod
If you dont mind tire wear or possible handling issues, NO you dont EVER need a camber kit. But on the other hand if you value your hard earned $$$ do the camber kit IF it's out of spec. As for the bubbles on the outside of the tire? Thats a possible safety issue. Do the bubbles look simialr to this?
Or sometimes they will balloon out about the size of a nickle or so.
CAUSE: WHEEL FLANGE COMPRESSING AGAINST THE TYRE INTERIOR. SUBSEQUENTLY THE CARCASS CORDS AND / OR INNER LINER ARE DAMAGED.
Due to their low sidewall heights, low profile tyres are more susceptible to damage caused by rim crush. The increasing popularity of tyres with profiles of 55 and lower may mean that tyre dealers see more tyres with damage caused by rim crush. Long periods of rain, which cause roads to break-up usually increases the incidence of rim crush damage.
Rim crush damage will produce a bulge or bubble, as shown in diagram 2.
The sidewall bulge is often the only external evidence of rim crush damage.
Old Dec 14, 2003
Thanks everyone
And that pic of the tire bubble is exactly what I got going on.
Old Dec 15, 2003
tfnaaf's Avatar
BLDNPSI Mod
Get new tires ASAP !
Old Dec 15, 2003
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
definately get new tires. as for the camber, with only a 1.5 inch drop, you should be able to adjust the camber enough without buying an aftermarket kit.
Old Dec 15, 2003
tfnaaf's Avatar
BLDNPSI Mod
There is no manufacture camber adjustments on out cars. Sometimes you can get a couple tenths of camber from the slack in the strut to knukle bolts but thats not really an adjustment per say. Best thing to do is get the alignment checked. THEN if its out of spec get the kits. If its not out of spec DONT. Or if your just a freak about your alignemnt get the kit to make it dead nutz on spec!
GolNat
Jan 12, 2021 09:06 PM
mHo2
Jul 27, 2015 12:57 PM
