what kind of shocks do yall suggest?
Old Nov 17, 2003
killakoala's Avatar
killakoala is an unknown quantity at this point
I was wondering what kind of shocks yall would suggest to go along with TEIN S-tech springs. Thanks.
Old Nov 17, 2003
Vinh's Avatar
OEM
Old Nov 17, 2003
killakoala's Avatar
how long before they blow though? I was gonna get full TEIN coilovers, but I figured Id cheap out and just get good springs with some damn good adjustable shocks. I have plans for autocrossing my car so the stocky shockys wont last long. are the s-tech springs good for autocross, or do I need something stiffer. Any suggestions. Any input would be appreciated. Thanks.
Old Nov 17, 2003
Zzyzx's Avatar
Autocross Junky
just pick up a set of Konis. and the S.tech springs would probably not be that good for autocross. way to soft of a spring rate. Look for a set of sport springs, rather then Lowering springs.
Old Nov 17, 2003
robbclark1's Avatar
Retired suspension supermod.
the only shocks out are Konis. That is it. You can get KYB G-2's but they aren't meant for lowing. you are going to spend more than if you got the teins. Konis are $500-550 and install will be between $2-300 unless you DIY. please search. This has been covered.
http://www.7thgencivic.com/forums/se...der=descending
Old Nov 18, 2003
HYPR DRV's Avatar
Since 1977
HYPR DRV will become famous soon enough
BTW: If you get Konis (pretty much your ONLY option) and you have coilovers, make sure you weld the perches on the back struts. I know it's not a good idea to put a torch near your shocks but many peeps are finding that the perches on the rear Konis don't hold the weight of the coilovers. Regular springs are better, supposedly. I'm just going by what I've searched and found out, so you don't have to.
rayman7
Jun 20, 2015 09:48 PM
2HondaCivics
Jun 19, 2015 12:06 PM
alex_nyc
Jun 16, 2015 01:43 PM
vtec_concept
May 24, 2015 10:27 AM
ademarco6
Nov 16, 2001 10:19 PM
