awd? fwr? or rwd?
Old Oct 8, 2003
i_SiG_Vtec's Avatar
i_SiG_Vtec is an unknown quantity at this point
awd? fwr? or rwd?
which ones is best ? what do u guys think?
which one is for my ride? (civic 03' ex coupe)
Old Oct 8, 2003
Zzyzx's Avatar
Autocross Junky
the best at what?
Each one has its advantages and disadvantages,
Fwd is cheep to build, and is safe for the average driver on the street.
RWD is good for putting a lot of power and torque down, but can have controll issues when its slipery out.
AWD is great when its dry or wet, but has a lot more power loss through the drivetrain. and if not properly tuned can have all the bad habbits of both RWD and FWD.
and your civic if FWD.
Old Oct 8, 2003
robbclark1's Avatar
Retired suspension supermod.
good explanation.
Old Oct 9, 2003
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
what?my civic came rwd and with a 5.7 ls1 you mean to tell me mine is differant ?
Old Oct 9, 2003
Drnknmnky13's Avatar
No...Mine came with that exact setup. It must be the Factory Performance kit stage 2
On a side note..I think right wheel drive is the best. My right front and right rear tires handle all my power..I can take a left like no other
Old Oct 9, 2003
R1Style's Avatar
What's "fwr"?
Anyways...
1) RWD is great but our cars don't even put out enough power/torque to necessate doing a RWD conversion... waste of money.
2) AWD would be totally stupid. On a typical FWD car, the horsepower loss from the fly to the wheels is generally around 11%-15%. On an AWD equipped vehicle you can loose anywhere upto 25% hp from the fly to the wheels. That means an EX would only put 101hp to the wheels... My Yamaha R6 put more power to the wheels then that.
Save yourself the trouble and money and stick with the current FWD setup. With the money you just saved, spend it on a turbo or engine swap. From there if you need to put the power to the wheels, invest in an LSD, stronger clutch, and grippy tires.
Old Oct 9, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
i got NWD, its a special performance kit from honda
darkmatter
Jul 27, 2015 03:53 PM
doncarbone
Jun 8, 2015 03:37 PM
Boilermaker1
May 23, 2003 10:20 PM
JoeB16
Oct 20, 2002 10:19 PM
