Strut bar combo..
El Pinche Turbo Mexicano
Strut bar combo..
Since i have a Air intake i'm preatty much stuck with the Neuspeed front bar, but what would be a cood bar for the rear??
Cuzco, Neuspeed??
Or Is there way i could fit a Cusco Front Bar, even with my intake??
thanks...
Cuzco, Neuspeed??
thanks...
Search and Learn
Do they even make cusco front strut bar for em2? if they have for rsx(Dc5) , might not clear hood. anyways cusco rear upper strut bar is the best. but cost alot. neuspeed doesnt make rear upper strut bar.
Neuspeed doesn't make a rear bar. The best one out is the cusco but it will cost ya. The OBX rear bar is pretty decent. I didn't know cusco made a front bar.
they make one, i think it in optauto.com, and its for EM2 chassis, it just says, only for automatics, and will not fit with an aftermarket intake...
The Cusco bar isn't gonna fit. The USDM cars (both the RSX and Civic) have the firewall brackets in a different spot. That and the RSX has an extra mounting spot on the towers for the stock strut bar... the Cusco one bolts there. So its a major project that probably isn't worth it. Just get a neuspeed, fabricate some brackets, weld them on and you can bolt that to the firewall.
I'm looking at going with a Neuspeed front upper, Progress rear lower and an OBX rear upper. Haven't figured out what I want for the front lower, but it'll probably be a Neuspeed X-Brace.
get the neuspeed front upper or the spoon one it fits. dc5@em2 has it on his, i have the neuspeed one and love it. for the rear get the cusco one or the spoon one as for lower go with the neuspeed combo or rsx sway with spoon tie bar.
Escaped Convict
I thought the Neuspeed rear upper tie bar is out...
for the RSX:
http://www.neuspeed.com/products/pro...ils.asp?app=37|RS&type=12<ype=ns_import&p_id=1032
it should fit ours.
just gotta drill holes, maybe.
same goes for the mugen one...
for the RSX:
it should fit ours.
JDM WHORE!!!
I got spoon front & rear upper strut bar with progress rear and front sways and it handles great. The spoon bar fits perfect, planning to get spoon lower front or x-brace next.
i spent too much money on spoon
and how do we know they are spoon?
not even an engraving on it
if you showed someone else a generic
and a spoon....there will be difficulty distinguishing the two
Raiool
Oct 1, 2015 10:42 AM
