Do I need An Alignment?
Old Sep 28, 2003
Tojo's Avatar
=) Im Bi-Sexual <3
Tojo is an unknown quantity at this point
Question Do I need An Alignment?
Ijust got a set of new rims w/ tires (they r balanced n mounted)
i been asking people if i need an alignment or not..
some said YES.. n some said no..
so what kind of ALIGNMENT do i need? and why do i need it?
i have a comfy ride.. the wheels r very stable
Old Sep 28, 2003
MORG655's Avatar
MORG655 is on a distinguished road
Assuming the diamter of your wheels/tires is the same as your last set of rims and tires, no you don't need to get an alignment. If the total diameter of your wheel/tire is different now, you may or may not NEED to get one, but one would be recommended. You don't want any premature wear on your brand new tires.
Old Sep 28, 2003
Tojo's Avatar
=) Im Bi-Sexual <3
they r 205/40/17
i have a 4dr civic
Old Sep 28, 2003
Deception2k1civic's Avatar
My car is goin to have a new look!!!
Deception2k1civic has a spectacular aura aboutDeception2k1civic has a spectacular aura aboutDeception2k1civic has a spectacular aura about
you should go to your local tire dealer. They should offer a free alingment check. I work at Just Tires and alignment checks are free. For a basic alignment it usually cost 65 bucks to set the toe and caster.
Old Sep 28, 2003
Tojo's Avatar
=) Im Bi-Sexual <3
lol ppl r crooked as ***
i bet they gonan say i need one even toh i dunt
Old Sep 29, 2003
well they should give you a read out of the specs of the toe, caster and camber. I know at just tires that the computer prints out all the specs in either green or red ink. Green beign good and red being bad. Take a look at it and if your car is way off from factory specs get it aligned.
Old Sep 29, 2003
robbclark1's Avatar
Retired suspension supermod.
if you just got tires without lowering, you do not need an alignment. even if it is off, it will only be off slightly so it is not a big deal. once/if you lower then get one.
Old Sep 29, 2003
flotsamm's Avatar
As long as the suspension wasnt modified, then you shouldnt need and alignment.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
TheRiddicles
Sep 21, 2015 01:28 AM
