Rear Sway Bar
Old Sep 22, 2003
bear's Avatar
bear is an unknown quantity at this point
Rear Sway Bar
I have a 2002 ex sedan that has a 23.5 mm STOCK front sway bar. I was wondering if anyone has bought and installed the progress 22mm rear sway/tie bar combo only with the stock front sway bar, NOT in conjuction with the progress 27mm front sway bar. Also, this applies if you have a coupe the a 25mm STOCK front sway bar. How did the car handle, neutral, understeers, or oversteers slightly with the STOCK FRONT SWAY BAR and progress rear sway bar. Thank you, your reply is greatly appreciated!!!
Old Sep 22, 2003
Zzyzx's Avatar
Autocross Junky
This is a bit of a vague question, as there are more fatctors that you didn't include that determine when and where the car will understeer/oversteer or be nutural...... The main one would be what Springs do you have? So unless some one has the exact setup that you have then what ever answer they give you will have to be taken with a grain of salt. because if I were to have the Progress rear bar with the stock front, and say H&R sport springs. then My car would handle differently then your car if you had say, Neuspeed Race springs.
SO with that in mind, I can only speculate as to how that setup will handle. More then likely the car is going to want to bring the *** end around a lot sooner then you are use to. and in High speed corners it may induce a bit of oversteer. not that having a bit of oversteer is a bad thing; as long as you dont do any thing stupid to make it worse like Hit the breaks.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Marco83
Oct 13, 2018 10:13 PM
GotSiR
Jun 23, 2016 04:06 PM
muniorbust
33
Aug 31, 2015 08:59 PM
