progress rear sway bar
Old Sep 19, 2003
bear's Avatar
bear is an unknown quantity at this point
I have a 2002 ex sedan that has a 23.5mm STOCK front sway bar. I was wondering if anyone has bought and installed the progress 22mm rear sway/tie bar combo only, NOT in conjuction with the 27mm front sway bar. Also this applies if you have a coupe with a 25mm STOCK front sway bar. How did the car handle, neutral, understeers, or oversteers slightly with the STOCK FRONT SWAY BAR and progress rear sway bar. Thank you, your reply is greatly appreciated!!!
Old Sep 19, 2003
Braydogg's Avatar
Braydogg is an unknown quantity at this point
I havent installed a sway bar on my car yet....but I was wondering did you feel a difference in the handle and etc....because I am looking at getting some put on my car???
Old Sep 20, 2003
HondaLuver's Avatar
Its a celebration bitches!
1. search
2. it hadles alot better its more of a nutral feeling
Old Sep 20, 2003
rscivic's Avatar
rscivic is an unknown quantity at this point
You are just asking about the rear one? I have the rear bar and the handling is much different w/ it. I had to have it installed just b/c the bolts were on so tight we couldn't get them off. One thing just to be aware of though is if you have an aftermarket exhaust. I have the Thermal and finally after a pain in the a$$ w/ it. I have the piping cut off and rewelded to fit around it and not sit on it like it was.
Good part, worth the $ IMO.
Old Sep 20, 2003
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
i think it oversteers, i heard the 19mm is more of a neutral feeling
Old Sep 20, 2003
robbclark1's Avatar
Retired suspension supermod.
if you get both, you will probably feel more neutral. PM Grey for more info. If you just get the rear, then most likely you will oversteer. If you just get the front, most likely you will understeer.
Old Sep 20, 2003
Pharoh's Avatar
Bobaganoosh!
I have both the front and the rear with tie bar and they're awsome. The rear really feels nice but the best thing about the front is that it helps get rid of tire hop! Too bad they haven't got an upper front and rear though. Had to go with a Neuspeed upperfront and some generic upper rear. The car is super tight...Can't wait to get my KW's put on to complete the whole thing..
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Marco83
Oct 13, 2018 10:13 PM
GotSiR
Jun 23, 2016 04:06 PM
muniorbust
33
Aug 31, 2015 08:59 PM
