motor mounts yet??
Old Sep 18, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
motor mounts yet??
are there any motor mount kits out for our cars yet? like energy suspensions or something? ive been SEARCHING for some.. cant find em. and i think i need em...LOL.. let me know ANY help is appreciated... thanx guys!
Old Sep 18, 2003
robbclark1's Avatar
Retired suspension supermod.
No motormounts. I don't know if manufacturers have invested the time into the D17 because of its so called limited potential. Call ES and see if they have anything in the works. If there is enough interested they will make them, but right now I dont think there is.
Old Oct 3, 2003
BIGLIMPDOG's Avatar
BIGLIMPDOG is an unknown quantity at this point
i need mounts to!!! Has anyone found them yet?
Old Oct 3, 2003
hothondacivic02's Avatar
hothondacivic02 is an unknown quantity at this point
you want the polyurethane motor mounts right , well first there no the mount its just inserts that go into the stock oem mount and make it stiffer i broke one of my motor mounts and found out that no one makes a motor mount for our cars so i had to order from dealer . but in the process i called energy and they said they had inserts for the motor mounts only they dont have a whole car kit yet just the motor mount inserts
Old Oct 3, 2003
hey bro... did you end up getting them? if so.. how much? and where can i pcik em up.. i want em like YESTERDAY!
Old Oct 3, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
u can make ur own if u want to take ur stock ones and add polyurethane to em ive seen that done before if u want to take ur stockers out and go crazy
Old Oct 3, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
Yes there are polyurethen ones out...search...the kit is like 300 bucks
Old Oct 4, 2003
robbclark1's Avatar
according to ES's website there is no hyperflex full system for our car yet. There are only control arm bushings and front sway bar bushings. If you found differently then post where you got it from.
Old Oct 4, 2003
CivicHX01's Avatar
trying to eliminate wheel hop eh?
jus FYI if you didn't know already, the vibrations of the engine which are usually absorbed by the softer motor mounts will be transfered to the cabin when u put stiffer ones in...
Old Dec 5, 2003
abmerop18's Avatar
Jam out with your clam out.
any updates on this? my wheels are hopping like crazy and time i even try to launch it, even from 3000 rpm. i dont know if it is because of my stock tires back on or the fact that the tires are bald. any advise on this?
Old Dec 6, 2003
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
how do u know if you need motor mounts, every time i start off in first gear, i hear a loud creaking noise from under the car?
Old Dec 6, 2003
robbclark1's Avatar
if you need motor mounts then your engine will shake more. and you will feel it shake when you stop and start.
Old Dec 6, 2003
Bellz's Avatar
I have a creaking noise too. It's only when it gets cold outside, like now. I thought it might be the strut bar or the spring making noises. Anyone know what this is?
Old Dec 6, 2003
robbclark1's Avatar
hmm it is really hard to tell guys. I think if it was the motor mounts, you should hear it when you START the car. It is really hard to tell without being near the car.
Old Dec 21, 2003
b18c1boy's Avatar
b18c1boy is an unknown quantity at this point
if its a loud popping noise when starting off its your motor mount. probably the front one. ive had to deal with dealership twice about these and i only have 45000 miles on my 2k1. have them check it out.
mistermenphis22
Jul 13, 2015 04:43 PM
manfredww1
Jul 12, 2015 07:31 PM
671civicLX
Jul 9, 2015 03:22 PM
