RSX rear sway Q
Old Sep 12, 2003
PicCoLoboi02's Avatar
PicCoLoboi02 is on a distinguished road
RSX rear sway Q
For people who have the RSX rear sway bar (19mm)...did your car raise a little big higher in the back? It seems like ever since the sway bar was on...the car seems higher. On the positive note...my car is like glued to the ground when i do turns.
Old Sep 12, 2003
robbclark1's Avatar
Retired suspension supermod.
no it should not raise it at all. i think you are imagining things
Old Sep 13, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
Alright, I think I can guess what happened.
You raised your car in the rear recently.
You're on lowering springs.
Your car's ride height still hasn't settled yet.
Old Sep 13, 2003
Zell- nope my car has been lowered for a little bit under a year.
Rob- I'm pretty sure i'm not imagining it heh...before i can fit like two fingers in the back and now i can fit like 3-4 fingers.
Old Sep 13, 2003
IronFist's Avatar
Mine didn't raise either.
IronFist
Old Sep 13, 2003
dacivic's Avatar
dacivic is an unknown quantity at this point
Nothing happen to mine. Did you install your sway upside down?
Old Sep 13, 2003
All Eyes On Z
When i mean raise, I meant lifted it off on it's rear wheels. Not raise the ride height, sorry.
Old Sep 14, 2003
Hmmm say if i did installed it upside down heh...do you think that could of been the result?
Old Sep 14, 2003
All Eyes On Z
The rear anti sway bar has nothing to do with the ride height of the car. It can only be spring related.
Why don't you just try taking the bar off and putting back on the old one? Every time you raise your car the springs are gonna have to take more time to settle back at the height it was. For the best results, use measuring tape. Measure the distance between the upper fender and the center cap. If the #s change, then you'll know if it was the sway bar or not. Just keep in mind that you've gotta wait for the springs to settle first though.
Old Sep 14, 2003
i'm gonna roll with this for a week and see if it goes down. If not i'm gonna go ahead and use your idea Zell...thanks
Old Sep 15, 2003
robbclark1's Avatar
If you bar is upside down it will hit the control arms. A few people, including myself, have done it. Might want to check to see if it is the right way.
Old Sep 17, 2003
Old Sep 17, 2003
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Mine didn't raise up either, and it also is glued to the road when I turn.
Wait, how can you put the sway bar in upside down? It didn't seem possible....
Old Sep 18, 2003
dacivic's Avatar
I had done that also. You can see it is touching or close to touching the control arm. It also bounce like crazy if you hit osmething on the road.
Old Sep 18, 2003
CiViCLiZeD714's Avatar
i have the sway bar too...my ride height seems to be the same
Old Sep 18, 2003
All Eyes On Z
My guess is people put it on the endlinks BEFORE bolting the bar against the subframe. I don't see how it's possible to have it on backwards either other than doing it like that. I just figured it out (I think) and I've heard this topic many times.
Old Sep 18, 2003
CapYoda's Avatar
Escaped Convict
I think I may have experience something like what you're talking about..
where the car seems higher... this usually happens after I jack up the rear of the car...
but it settles after a quick drive... its obviously higher too.. cuz I can fit like my head in there or something instead of just fingers. heh (exaggerating but u get the picture)
sway bars are actually springs... the sway bar connects the two LCAs, I could have sworn there's a way for it to get the LCA stuck in a position... I remember reading about this before... or was it something to do with the endlink? hmm.
if I remember I'll post some more worthwhile info. heh. sorry.
Old Sep 18, 2003
it's fixed now..it was on upside down heh heh heh oopss.
Old Sep 19, 2003
JCiv03's Avatar
lol tsui
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
redcloud
Sep 7, 2015 01:45 PM
Viczhou
Sep 2, 2015 07:55 PM
Shadow277
Aug 31, 2015 12:30 PM
