Where to buy this?
Re: Where to buy this?
Originally posted by Vinh
Neuspeed Front Sway Bar (25mm)
i've searched and searched....can't seem to find it....
2002 Honda Civic HX Coupe
Autocross Junky
WHy are you interested in the Front anti-roll bar? (Sway bar).
If your car is oversteering too much then maybe, but other wise........????
What other things have you done with the suspension??? If your Profile is right and you only have Ground control spings, then upgrading the Front anti-roll bar is DEFINITLY NOT what you want to add to the car. Un less you want to make the car understeer even more.
I need TP for my bunghole
WWW.NEUSPEED.COM (they don't display it on the site so call them.)
I live five minutes away from them and they always have stuff for cars that isn't on the web site.
http://www.neuspeed.com/contact/cont...type=ns_import
Originally posted by sexcivic2k1
neuspeed.com sells bushings for it for 19.95...
but i think u should jus upgrade the rear sway bar instead (if you haven't already)
thanx for the input guyz......
i just installed the
(1) Neuspeed Front Upper Strut Bar
(2) Neuspeed Cross X-Brace Bar
(3) Neuspeed Lower Tie/Sway Bar Combo
(4) Spoon Front Lower Strut Bar
(5) Spoon Rear Upper Strut Bar (on order)
as you can see, i have expensive taste
Originally posted by dragin
Spoon Front Lower Strut Bar were did u find this at? an how much?
juror
Suspension DIY
Jul 30, 2019 03:28 AM
viperGTS
Jul 27, 2015 08:38 PM
