Clicking and Ping and Pong Noises
Old Aug 16, 2003
gizute's Avatar
gizute is an unknown quantity at this point
I have some POS coilovers and i was wonder if i were to get some Skunks would all that ****ing noise go away? Those things are clanking every time i turn.
Old Aug 17, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
get coilwrap.. its like $3 at radio shack..
Old Aug 17, 2003
gizute's Avatar
also, will skunks be ok with koni struts?
Old Aug 17, 2003
robbclark1's Avatar
Retired suspension supermod.
yes, but the money you are spending on that you might a well get true coilovers for a few hundred more
Old Aug 17, 2003
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
did you remember to also use the stock bearing ring and not just the upper mount? sometimes that piece is practically glued to the stock spring cap. with coilovers, you will always need to re-use it
Old Feb 4, 2004
jttegx's Avatar
OMNES AD UNUM
what does this 'coilwrap' look like? i was assuming it was the black tube like thing thats ridged. but when i went to radioshack today, they pointed me out to this copper wire kind. the clerk told me it was used for better frequency or sumthin like that.
please let me know asap because i am getting skunk2 coilovers soon and i heard those make noises too.
Old Feb 4, 2004
jttegx's Avatar
OMNES AD UNUM
i just noticed this forum was created like last year
Old Feb 4, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
it will go away
when i had my new eibach springs on i had same noise when i turn and stuff....but after like 2 weeks it went away
Old Feb 4, 2004
clownprince's Avatar
Ricerus Maximus
It will look like a rubber tube that someone has done a spiral cut on. It just wraps aroudn the springs in a spiral. I'll see if I can get some pics of some. Also, make sure to grease up the points of the suspension that turn, i.e. on top of the struts.
Old Feb 4, 2004
jttegx's Avatar
OMNES AD UNUM
what material is it made out of?
Old Feb 4, 2004
KeNsHiN's Avatar
LEVA
im having the same problem .................
Old Feb 4, 2004
BobbyStylz's Avatar
BobbyStylz is an unknown quantity at this point
I had the same problem, couldnt stand all the noise and the horrible ride. So, i went out and got Kw V2 best money I've ever spent.
Old Feb 4, 2004
hondaciv01's Avatar
hondaciv01 is an unknown quantity at this point
just take a look at the suspension set up again before you do anything.....then go to the other solutions where you spend money
Old Feb 4, 2004
showcasefreak's Avatar
showcasefreak is an unknown quantity at this point
that noise would probably be that something is loose or its not tighten or something is out and needs to be replaced
WaryDriver
Aug 22, 2015 06:50 PM
Green02civic
Jul 27, 2015 10:48 PM
Smokahontas123
Jul 22, 2015 10:07 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
