another Lower Control Arm question
Old Aug 6, 2003
wonderz's Avatar
wonderz is on a distinguished road
Question another Lower Control Arm question
Ok, so when I buy new front lower control arm, does it come with brushings? or do i have to buy those separate?
also can someone give me the torque spec of the bolts for front lower control arm?
TIA
Old Aug 14, 2003
opto_isolator's Avatar
Old Aug 14, 2003
wonderz's Avatar
Originally posted by opto_isolator
ok, I already did that before I post, but i can't find anything. If you can find another thread that discusses this issue, please give me the link since I assume you are sure that it can be done thru search.
thx
Old Aug 14, 2003
Funny since I just did a search for "control arm" and came up with a lot of hits:
http://www.7thgencivic.com/forums/sh...ht=control+arm
These are all threads which I have posted in - most contain exactly what you are looking for.....
Old Aug 14, 2003
wonderz's Avatar
ok, i read all those posts before....2 about energy brushings, one about you getting rear torque spec, and another one about diy brushing...
none have i seen have front torque spec or if the oem comes with their own brushing when i buy it...
thx for the searching tho.
EDIT: come on ppl, its just a yes/no question and some numbers...no one know?
Old Aug 15, 2003
Ok, since we are all friends here (and I had problem finding info before I bought my helm manual) - the lower front control arms I believe do not come with the front bushing - don't quote me. The best place to check is majestic honda (check google, its late, I am too lazy to put the URL here). They will tell you what bushing is included which is not. I believe only the rear bushing of the front control arm is included, and the front has to be pressed in. The front control arm torque specs are:
61 lb-ft of torque for the front and rear bolt. The balljoint nut requires between 43-51 lb-ft of torque. Finally, the nut on the sway bar requires 29 lb-ft of torque. Anything else just ask (I'm feeling generous, heheh)....
Old Aug 15, 2003
wonderz's Avatar
thx for the generosity(sp?)
gonna get this thing done first thing in the morning since i got my specs. and gotta go buy some cotter pins too...i think
GolNat
Suspension DIY
May 12, 2022 06:49 AM
GolNat
Sep 10, 2015 08:25 PM
beachglass
May 22, 2015 09:59 PM
tomg
May 21, 2015 07:05 AM
bsmiley
Apr 27, 2015 01:27 PM
