adjusting koni's
Old Aug 1, 2003
VRoomPSHeRt's Avatar
VRoomPSHeRt is an unknown quantity at this point
Exclamation adjusting koni's
hey everyone, i juss got my koni installed. i was wondering where is a good dampening level to set the shocks. i tried a bunch of setups, but i want the opinion of the other koni owners. Oh btw, when u guys installed ur koni's, did the car get raised? like half an inch or so??
Old Aug 1, 2003
djmota's Avatar
i got mine right in the center, which works good for the springs that are on my car.
Ya the car came up about 1/2 inch or so after the instal but it will settle back down after a while.
Old Aug 2, 2003
Snort2001's Avatar
Snort2001 is an unknown quantity at this point
yea, i have mine set in the middle as well. im going to have to turn it a notch up though cuz i've noticed that my rear and front bounces a bit. but it's all about personal preference. try all the combinations and see what YOU feel most comfortable with. cuz i might feel that it's the best at the middle yet you might feel it's better when it's stiffened all the way.
Old Aug 2, 2003
TOOLOWCIVIC's Avatar
How can I adjust the rears cus I dont have that lil **** for the back and the front ones too big to fit. What can I use to adjust it without brakin the lil adjuster.
Old Aug 2, 2003
Snort2001's Avatar
you dont' have the lil knobo for the back?? meaning you lost it? or never got it? hmm...i guess you can try calling koni and see if they can send you another one? sorry man..cna't help you much there. now that i think of it...i dont remember where i put my adjusters either...
*EDIT* you MIGHT be able to use a wrench or soemthing to turn the adjuster? you MIGHT. but i wouldn't try if i were you...you dont wanna damage it.
Old Aug 2, 2003
who is that asian girl snort2001?
Old Aug 2, 2003
I tried it before with one of those needle nose pliers cus thats what they told me to do and I broke it so I ended up gettin another one. Damn theres gotta be a way to adjust it cus I have never really messed with it.
Old Aug 3, 2003
Snort2001's Avatar
my girlfriend....
hahaha..jk...she's Lee Hyori from F.I.N.K.L.
Old Aug 3, 2003
QTcivicGirl's Avatar
QTcivicGirl is an unknown quantity at this point
i used plyers...it was a pain in the ***, but oh well, it was worth the effort
Old Aug 5, 2003
deeznuts's Avatar
deeznuts is an unknown quantity at this point
u can use your front ones just use a plyers to bend the metal a little thats in the way. otherwise i have a rear one i would sell you for $5 plus s&h
Old Aug 6, 2003
Snort2001's Avatar
hmm...that's odd, cuz i tried adjusting my rear koni's today...and that metal plating was in the way...even for the rear adjuster ****. both of them didn't fit...dunno why. i guess ill try to bend the metal out of the way...
Old Aug 6, 2003
deeznuts's Avatar
yeah the metal is in the way for both *****, but if you use the taller ****, u hafta bend the metal more. a rubber mallot and a screwdriver is fine. you could also cut the metal with a snips or better yet a plasma cutter!
Old Aug 6, 2003
I've got the metal bent back enough for the liil **** but since I dont have it Im gonna have to bend it some more.
Old Aug 6, 2003
Alex1's Avatar
guys someone pls answer my question from experience... is it true that the koni shocks and struts will lower the car 1/2 an inch again after it settles? or it will just raise it 1/2 inch permanently?
Old Aug 6, 2003
deeznuts's Avatar
the rear may raise a little bit. i think more like 1/4 inch. but it will take a few days for your springs to settle after having the tension off of them.
Old Aug 7, 2003
Alex1's Avatar
that does not really answer the question..
Old Aug 7, 2003
deeznuts's Avatar
ur car will raise about 1/2 inch intially, but after a few days of driving your springs will settle and lower your car about a 1/4 inch. so after the 1/2 raise and then 1/4 inch drop, ur overall height will raise about 1/4 in. so 1/4 inch raise in the end
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
