Anyone have Eibach Sportlines???
I am getting 18 inch rims with 215/40-18 tires. I was looking at the Eibach susepnsion kits. Does anyone know if I will be able to drop my car with EITHER kit and not have to worry about the wheels grinding against the wheel well or anything? I was thinking using the prokit since it only has a one inch drop and I wanted to save room for a body kit. Would I still have enough room if I used the Sportlines and dropped it 1.4 inches?? DO I need a camber kit too? or is that supplied with the springs? Where can I get a camber kit if it is needed (as I am sure it is)? Any help or suggestions on this matter would be most appreciated. I want to have a great look while still having enough room for a body kit. Thanks folks.
I have the Sportlines. You can check out what it would look like at member's rides.
I have 205/40 -17's, so I have about 3/4 of an inch between the tire and the wheel well.
You will need camber kits. I used the Ingalls and everything is working fine.
For me, the drop is good enough to look lowered and handle well. I usually do not have too many issues except on steep driveways. Driving along on the road is firm, but comfortable.
Search and Learn
i heard sportline drops around 1.75 after springs settled.
yes i would suggest you to buy camber kit but its not NEEDED.
theres groupbuy on camber kits.
i would go with prokit because of bodykit. thats just me
Shadow277
Aug 31, 2015 12:30 PM
