whats up with my drop????
Old Jul 24, 2003
Veop5's Avatar
Veop5 is an unknown quantity at this point
Question whats up with my drop????
I just got neuspeed race springs and spc front and rear camber kit installed this week. After they were done installing everything the back seemed to be a little higher than it should, meaning i still had about a 3 finger gap in the rear. the front was not even a fingers gap. So i guess what i am getting at is will the back come down after the springs settle or did the boneheads install the springs and camber kit in wrong. Just a side note, it is only on one side in the rear, the other side seems to be lowered the right amount. Can someone help me with this, thanx.
Old Jul 24, 2003
Green Civic's Avatar
Wait. So only one side has a 3 finger gap? Do you have a pic of this? Sounds like that one spring is installed wrong, upside down. The springs should all have the same height and then let time set in to break in the springs. Thats what I think.
Old Jul 24, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
The rears are stiffer than the fronts... they might have to set in a little bit. The bigger drop in the front doesn't surprise me. If they're race springs then they're probably set to neutralize the car out... so if that means the rear has to set a little higher, than thats the way it goes. There's no lip in the front, there is in the back so they've gotta leave a little room for that too.
Before you do anything, drive for a week and see if they settle down a little bit. Even then, I bet the back will still set higher.
Old Jul 25, 2003
VNlilMAN's Avatar
The Standard One
ya the neuspeed race rears are higher in the rear. probably about .5"-.75" higher. to even out the drop you can cut a DEAD coil.
Old Jul 25, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
From what I remember, the left side of our cars is heavier and sits a little lower... When I installed my Tein SS my car was sitting funny, then I adjusted the coil overs so it was all even on all 4 corners....
Old Jul 25, 2003
Jodster's Avatar
Post Whore General
It happened to me with my nuespeed race springs. The back looked like it didn't drop very much. So I took my SI out for a ride and took some curves at a high speed to test out the new springs. After 5 minutes of driving and hard cornering, the back settled down in place.
Old Jul 25, 2003
ShowCivicLX02's Avatar
ShowCivicLX02 is an unknown quantity at this point
Lemme c a pic of this sounds interesting Lol
Old Jul 25, 2003
Veop5's Avatar
Thanks for all the information and thoughts guys, i think i will see if the spring in the back settles after a few weeks, if not i think i am going to take it back to the guys who installed them.
Old Jul 26, 2003
dragin's Avatar
dragin will become famous soon enoughdragin will become famous soon enough
i got neuspeeds springs on mine, its about 1 finger all the way around on the stock rollers... no lean its all even....
Tedverseti
Sep 29, 2015 05:41 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
Hollywoodsnake
Sep 20, 2015 12:58 PM
Juanb24
Sep 15, 2015 12:39 AM
