just installed neuspeed x brace
Old Jul 17, 2003
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
well after having it sit in my trunk for months now, i finally got it installed at my neighbors house who has jack stands, i was gonna get it professionally done but it cost too much and i had no time. i instantly felt the front much more tight when i pulled out of his driveway. the front is so stiff now and the rear is not, im planning on getting the rsx sway bar in like 2 weeks, i took some corners really fast, i couldnt really tell if the x brace was working that much cause my car kept sliding and my tires screeching like crazy(stock firestones), but i took some wavy roads quick and i felt a difference. i just have the x brace with the neuspeed front upper strut bar and it made my front much more stiff, i reccomend these two parts together
Old Jul 17, 2003
robbclark1's Avatar
Retired suspension supermod.
Good job. i have those parts.
Old Jul 17, 2003
tekgnosis's Avatar
Ask me about your mom.
a ha. this is the one thing missing from my suspension setup.
I gotta get this!
Old Jul 17, 2003
Yukonart's Avatar
Yukonart will become famous soon enough
The reason you can tell it's working is BECAUSE the shitty stock Firestones are squealing. Your suspension up front is hella stiff, and the rear-end wants to break loose on you. I tested this inbetween installing mine and the rear tie bar/ sway bar combo. Once I did that, the rear tracks a lot better, and the tires grip better.
However, I hope you plan to upgrade your springs and shocks, or go with full coilovers soon. Taking corners like that on your stock setup will blow those struts in no time. Not to mention those tires really don't care for the added abuse.
Good choices on some of your first mods, though.
Old Jul 18, 2003
HondaLuver's Avatar
Its a celebration bitches!
cool, now get better rims/tires
Old Jul 18, 2003
yeah, today i took a turn quick and the front was really stiff and stable and the back was leaning like crazy. the rsx sway bar should alleviate that problem. i really do recommend the x brace, i noticed a difference
Old Jul 19, 2003
jwsisme's Avatar
jwsisme is an unknown quantity at this point
Wait till you hit a bumpy, rough, curvy road.
The x-brace keeps the car tracking straight ahead, much, much better.
Old Jul 20, 2003
MadWheel's Avatar
Premium Boosted Member
Where'd you buy it from if you don't mind me asking?
Old Jul 21, 2003
i got it on a neuspeed group buy a couple months ago
Old Jul 21, 2003
MadWheel's Avatar
cool, thanks man
Old Jul 21, 2003
robbclark1's Avatar
you can get it from CircaX.
Old Jul 21, 2003
wannabeblown's Avatar
wannabeblown is an unknown quantity at this point
Was it difficult to realign the holes in the control arms after you took the bolts out?
Old Jul 21, 2003
Yukonart's Avatar
Best overall selection and prices (when shipping is factored-in) that I have found so far is Tornactive.
Ordered all my Neuspeed suspension stuff there. . . saved about $60 over the closest competitor.
Old Jul 21, 2003
SedanBoy's Avatar
SedanBoy is an unknown quantity at this point
how is the install?..... relatively easy?...
Old Jul 22, 2003
Yukonart's Avatar
Install takes about 10 minutes once it's up on jack stands. You don't need any additional hardware. You simply remove the bolts from the lower control arms, install the brace, and replace the bolts. Torque to spec, and you're done.
Old Jul 22, 2003
i didnt torque to spec though, me and my friend tried to tighten it hard, i will get a torque wrench eventually and see where its at
Old Jul 22, 2003
HondaLuver's Avatar
remember that the x-brace and the hp race header is not compatiable
Old Jul 26, 2003
dragin's Avatar
dragin will become famous soon enoughdragin will become famous soon enough
just got my x on friday, putting it in on monday with my exhaust and cai
glade to hear it makes the car track better thats what i was hoping...
how much did you pay for it?
Old Jul 27, 2003
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
Do you notice any problems with clearance??
Old Jul 27, 2003
dragin's Avatar
its supose (sp) to not have any clearance issues... illl say for sure monday
Old Jul 27, 2003
HondaLuver's Avatar
well i think there are, because now you have 4 things under your car that you didn't have befor, when i had mine on, i scraped in alot of places i didnt' befor, like on speed bumps or bumpy roads
Old Jul 28, 2003
mine doesnt have problems with clearance, it never scraped, but my car is not lowered though
Old Aug 3, 2003
dragin's Avatar
only thing i wack it on is things that are only high in the center part of the car when i drive over em. and the other is my exhaust will rub it occasionally... other than that no probs at all easy as hell to put on also..... and made a hufge diffrence in how the car drives
Old Aug 3, 2003
jwsisme's Avatar
If you pull out of a driveway too fast you'll likely hit the x-brace mounting point.
I did, but not too bad, and it held up pretty well.
The front bolts are slightly hard to get back in, when installing the x-brace.
I freaked for a sec when I couldn't get the bolt back in.
Since I installed it without lifting the car, it took a bit of effort to get back in.
Nothing to difficult, as I am no mechanic.
Old Aug 8, 2003
clownprince's Avatar
Ricerus Maximus
Can this x-brace be used along with a Progress front sway bar or is this a different route to tuning the front suspension?
Old Aug 9, 2003
jwsisme's Avatar
You shouldn't have any trouble with the swaybar and x-brace.
Old Aug 11, 2003
Ricerus Maximus
Sweet, so I'm guessing that they would not overlap any.
Old Aug 11, 2003
HondaLuver's Avatar
the sway bar from progress or any other company goes in the stock location
Old Aug 12, 2003
AntDeezy's Avatar
why not ?
Old Aug 12, 2003
IronFist's Avatar
The x-brace stiffens up the front end, right? So that would create more understeer, right? Don't our cars understeer enough as it is? Someone correct me please.
Also, does this stiffen up the chasis, or does it cause less body roll?
IronFist
