Neuspeed or Progress springs?
Old Jul 15, 2003
Tojo's Avatar
=) Im Bi-Sexual <3
Tojo is an unknown quantity at this point
whats the difference between these too
ppl told me to get neuspeed n some told me to get progress?
thanks
Old Jul 15, 2003
reytito's Avatar
depends on the drop you want. dont; listen to what other poepel are telling you to buy. its your car. if you want a bigger drop..get progress. if you want a milder drop...neuspeed. thats the biggest difference.
Old Jul 16, 2003
civicvtec1ps's Avatar
Search and Learn
there are 2 different kinds neuspeed springs
neuspeed sports = 1.75
neuspeed race=2.25
i belive progress is 2 drop.
different drops..
Old Jul 16, 2003
Tojo's Avatar
=) Im Bi-Sexual <3
i want a comfy ride?
so i go for the neuspeed sports?
n do i need shocks?
Old Jul 16, 2003
reytito's Avatar
after it settles progress is about 2.25.
Old Jul 16, 2003
Search and Learn
n do i need shocks?
eventually yes, you will need to buy aftermarket shocks(koni is the only that are out on market right now).
if you are looking for comfortable ride. save up and buy full coilovers. well worth every penny
Old Jul 16, 2003
Civicly02's Avatar
progress slams your ride and you will need a camber kit while neuspeed is a milder drop and I think you will need a camber kit as well. It is all up to you.
Old Jul 16, 2003
reytito's Avatar
oh it ain;t THAT slammed...heres my car:
Old Jul 16, 2003
Tojo's Avatar
=) Im Bi-Sexual <3
now i need camber kit??
i thot i need shocks
Old Jul 16, 2003
Search and Learn
you will eventually need to replace oem shocks later.
also i would suggest you to buy camberkit if you lower your car more than 1.75....
Old Jul 16, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
camber kits are suggested, but not nessesary, lower ur car, wait til it settles, if the wheels tilt in, get a camber kit...
Old Jul 16, 2003
Search and Learn
my drop without camber kit
Old Jul 16, 2003
Yukonart's Avatar
Yukonart will become famous soon enough
Even if you can't see negative camber in your rear wheels, it'll likely still be there. . . even after just a 1.5" drop. Ever car is a little different, and some need a kit with as little as a 1" drop!
I have the H&R Sport (1.3" claimed drop) and I needed camber kits FRONT AND BACK.
Even if you don't think you'll need the kits, at least budget for them. After your car settles from the spring install, get it fully-aligned. The tech will tell you if you need camber kits. If so, get them ASAP and install them, then go back for another alignment. Most finer shops will give you a FREE realignment in the first 30 days after your initial one. USE THAT. That offer will save you $50-70 from another alignment.
I can't stress this all enough. Anything more than about 1 degree off will start to unevenly wear your tires, especially if they're on 17-19 inch rims. Then they'll wear the inside edges of the tread even faster.
Budget for the kits. If you DON'T need them, great!
Old Jul 16, 2003
WannaBFast's Avatar
^^^ exactly.. like i said.. its recomended, but not necessary.. i forgot to add in most cases
but if u wanna be safe on the tire wear, go for it.. as for me, i dont really notice any tire wear.. but then again.. i got the oem spec tires... meaning they are 185/65/15's so i dunno if that matters to u at all
Old Jul 17, 2003
sexcivic2k1's Avatar
negative camber, get a camber kit
Old Jul 17, 2003
Search and Learn
sold my car.
TEIN ss is sold too.
Old Jul 17, 2003
skaterboy's Avatar
skaterboy is an unknown quantity at this point
I dont know about those two, but I really do like either eibach or H & Rs... Sorry this is not what u asked
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
