lowering Q
Old Jul 16, 2003
MIT's Avatar
MIT
MIT is an unknown quantity at this point
Question lowering Q
needed some opinions from all lowering experts here:
I got my tein basic, if i want to lower my car 2" all around with SI rims, 185/65/15 tire. so do i needed to lower my front a bit more? cuz i dont want my front set higher than rear. i want it flush look. one more thing, anyone know the wheel gap there if i lower 2"
thanks,
Old Jul 16, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
no one can tell you how its going to look... each car is different.. depending on shock wear and tear, I.C.E. , sedan , or coupe.... just get the coilovers on and pick your height.
Old Jul 16, 2003
civicvtec1ps's Avatar
Search and Learn
you gotta play with height to see what kind setting you like.
its easy to adjust anyway
Old Jul 16, 2003
MIT's Avatar
MIT
so if i re-adjust the height, is that means need to re-alignment again?
also one friend installed Tein basic already, he had some problem cuz he used stock base mount, when he jacked up the car, it move, and makes the noise when turn. ( is that means tein spring is small, OEM civic spring is bigger so that mount wont fit right?), anyone can solve this problem, or just get the Tein base mount (pilloball) to fit it right?
thanks,
Old Jul 16, 2003
Search and Learn
thanks,
everytime you readjust the height you will need new alignment.
hmm stock uppermounts worked perfectly fine. no noise.
Old Jul 17, 2003
MIT's Avatar
MIT
if i lower my basic damper 2" all around, then the front will higher than rear right.? is like no 2 finger gap for front, and no gap for rear......need help, i'm going to lower my car soon.......
thanks
Old Jul 17, 2003
Search and Learn
thanks
just play around with height. tahts the best way.
its not even hard to adjust height.
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
bhollie
Sep 22, 2015 11:08 PM
