is tihs possible?
Old Jul 4, 2003
cryption's Avatar
2003 Nissan Frontier
is tihs possible?
Could i do a 3.5" drop on 17" rims with 215/40ZR17 tires and not have my tires rubbing.
Old Jul 4, 2003
reytito's Avatar
one word...dam.
Old Jul 4, 2003
cryption's Avatar
i allready have the drop ... I don't think it will rub but i was wonderin if anyone else had tried it? It'll look hella sweet if it works ... even if houston streets make it cry ... I drive slow anyway
Old Jul 4, 2003
cryption's Avatar
I have the drop .. in my trunk .. i havent put it on yet ... and I'll need a badass camber kit too i know
Old Jul 5, 2003
cryption's Avatar
oh and they are cut goldline springs, I couldnt afford anything else so i had to get them used from a friend
Old Jul 5, 2003
luvvegas777's Avatar
banned from avatar useage
luvvegas777 is an unknown quantity at this point
don't turn left or right and you'll be fine
Old Jul 5, 2003
Weaponx12o's Avatar
haha yup. with 3.5", you'll have to cut out the wheel well so you can turn. i dont think you'll rub, but your camber and tires will be f*cked. dont do it if you plan on driving your car a lot.
Old Jul 5, 2003
cryption's Avatar
well damn, whats like the most i could possibly do?
Old Jul 5, 2003
on the rear wheel well you'd have to cut away at the lip to get an extra inch of clearance, i'd guess close to a 3 inch drop for daily driving
Old Jul 5, 2003
this is 2.25 inches, 205/45/17
Old Jul 5, 2003
JRS1civic's Avatar
JRS1civic is an unknown quantity at this point
i had a 3.5 drop and because of it i went with 16's. i raised the front a little just to be on the safe side, and also because i got 205/55, the tires were a little to beefy
Old Jul 5, 2003
Weaponx12o's Avatar
you sure thats 2.25"? heres my ride on B+G's at 2.25". the tires tuck in about 1/4 to 1/2 an inch.
Old Jul 5, 2003
Weaponx12o's Avatar
2.75" or a little before 3". you will have to cut the wheel well at around 3" and roll the rear fenders
Old Jul 5, 2003
your tires are tucked cause your running a higher profile tire where as my tires are 45 compared to stock which is 75
Old Jul 5, 2003
cryption's Avatar
i like how both of those look, so yea I guess i'll go with like a 2.75. Any of y'all know where i can get it CHEAP?
Old Jul 5, 2003
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
no, that wouldn't matter; if anything your tires would tuck even more for being larger than stock in diameter. Do you have springs or coils?
Old Jul 5, 2003
cryption's Avatar
dudes if you can find some hella cheap coil overs i would appreciate it. I guess ajustable, i got 215/40-17s and want a nice sized drop ya know
Old Jul 5, 2003
Weaponx12o's Avatar
actually, 205/45/17 are pretty close to my stock tire diameter. which is 185/65/17, NOT 75 like you thought. if you dont believe me, check out the tire calculator. if i put your rims/tires on my ride, i will rub.
it seems like your ride is 2" in the front and 2'25" in the rear. mine are 2.25" all the way around
Old Jul 5, 2003
Weaponx12o's Avatar
cryption, what's the width of your rims? if they're 17x7, then you would be fine with a 2.75" drop (with no rubbing). if you have a 17x7.5 width rim, then 215 tires might be too wide and you might rub.
are you planning on getting full coilovers or sleeved? if you want full, get B+G's or tein, but they cost at around 1000. if you just want sleeved, get ground control or skunk2. note that you would also need new shocks, especially with that low of a drop.
Old Jul 5, 2003
i have tein ss coils
Old Jul 5, 2003
that's true they are close to the same diameter overall, i have tein ss coils and the front is as low as it can go and the rear is set as close to the front as possible otherwise if it was as low as it could go then the rear always sagged.
Old Jul 5, 2003
Weaponx12o's Avatar
thats why it looks high, i think teins can only give a 2" drop all around. i have B+G coilovers, same with mex
Old Jul 5, 2003
Mex's Avatar
Mex
actually in the rear TEINs can go like 3" i think. it's just the fronts that cant be slammed I'm lovin my B+Gs
Old Jul 5, 2003
HCCriminal's Avatar
an0therpin0y
yeah, thats the only thing about tein ss...
but anyways .. your front tires will tuck but will not rub cryption ...
those are my springs ... why didn't u ask me !
ajhdragon
28
Feb 8, 2005 07:29 PM
eklipz
Apr 5, 2004 03:23 PM
Rafavtec
Oct 9, 2002 10:03 PM
