does anybody has a DIY on Rear SPC Chamber
Old Jul 3, 2003
DragonZ's Avatar
DragonZ is an unknown quantity at this point
Question does anybody has a DIY on Rear SPC Chamber
i just got my rear spc chamber and dont have a clue to put it on, i called the shop and they say it will be $55 an hour for labor in my car, so i decided to put it on my self.. any help would be appriciated, if with pics it will be greatly appriciated
Old Jul 3, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
its REALLY easy to put on, just jack the back end up, remove the tires, then you'll see the old pieces, just remove those, and put the new ones on, its %100 bolt on, took me like 20 minutes... Just start doing it and you'll see how easy it is. I used a level to make sure my wheels were somewhat perpendicular and got an alignment shortly after. Hope this helps. Later...
Old Jul 3, 2003
Weaponx12o's Avatar
heres the DIY
DIY: rear camber kit install
Old Jul 4, 2003
CivicHX01's Avatar
make sure you lower the car before you tighten the big bolt (the one one that connects to the brakes)... you need to preload the bushing or else it won't sit right...
Old Jul 5, 2003
DragonZ's Avatar
thank you very much for all of yhal inputs, thats why this place is the bomb...
GolNat
Jan 12, 2021 09:06 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
carid
Nov 7, 2015 01:46 AM
henrytn
Aug 11, 2015 10:01 PM
Curtchuk
Aug 5, 2015 02:14 PM
