rsx sway bar conversion problem
Old Jun 30, 2003
Bluelle's Avatar
Bluelle is an unknown quantity at this point
I searched but I couldn't find the answer..
endlink problem... nut won't come off, turns along with the bolt. Anyone have this problem? HELP!!!!!
Old Jun 30, 2003
djmota's Avatar
get a small pair of vise grips and grab the inside of the endlink with em The nuts are self locking so its going to be a paint all the way of.
Old Jun 30, 2003
robbclark1's Avatar
Retired suspension supermod.
you need an allen wrench. look at http://www.xenja.com/7thgencivic_RSX..._DIY/index.htm for the DIY
Old Jun 30, 2003
Lifelike's Avatar
Lifelike is an unknown quantity at this point
I got a 02 civic ex and i put the skunk2 coilovers on and I am disgusted with the snapping and popping they make I talked to some people and they dont know what to make of it. I got the front raised all the way and it leaves me with like half an inch from my tire to the well.....I wanna get rid of them im terrified to drive it just keeps getting worse.... Got any suggestions for any kits? Is B+G pretty good.
Old Jun 30, 2003
robbclark1's Avatar
What does that have to do with the RSX sway bar?? please search around for the answer to that question.
Old Jun 30, 2003
Lifelike's Avatar
sorry wrong topic
Old Jun 30, 2003
Yakkolio's Avatar
Yakkolio is an unknown quantity at this point
yep a 5mm allen wrech is needed...and you cannot use a socket wretch either so it makes the job that much harder without the right tools. But the endlinks are the most difficult...after that everything is easy. Also remember to put your RSX sway bar on the right way
Old Jul 1, 2003
brents1's Avatar
brents1 is an unknown quantity at this point
ha ha!! that was really funny. Waaaayyyy off topic. good question though...
Old Jul 1, 2003
tekgnosis's Avatar
Ask me about your mom.
I had the same problem!
I was trying to use a ratchet...no dice. So I switched to an allen key and a wrench...no dice.
SO..then I fired up the air compressor. I used the less powerful air ratchet, and it came off without even having to worry about the allen key part!
find a friend with an air compressor, and do the stuff at his/her house!
Old Jul 3, 2003
artychris's Avatar
artychris is an unknown quantity at this point
I just vised it with a wrench and turned it with all my strength.
Although I did strip the nut pretty badly.
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
Jodster
Dec 15, 2001 07:49 PM
Firefly
Nov 28, 2001 06:13 PM
