Sidewall on steel wheels
Old 01-25-2013
Tiki's Avatar
Tiki is an unknown quantity at this point
Ok, so I searched and couldn't find anything so here's my question, Im running the steel wheels on my 2001 civic the oem tire is 185/65-15, can i go lower on the sidewall? how does this work on a steelies compared to an aftermarket rim, sorry if this a silly question lol. Thanks ^__^
Old 01-25-2013
Prelude Owner
GolNat's Avatar
Re: Sidewall on steel wheels
Yea you can go with a lower profile. It works the same as on aftermarket wheels. The reason that you decrease the sidewall is to maintain the factory rolling diameter. If you go from a 15 inch rim to a 17 inch rim you now need less sidewall to maintain the same rolling distance of the tire so that it does not throw your speedo off. By decreasing the sidewall on the stock wheels you will throw off your speedo.
Here is tire calculator tool to tell you how much it will be off:
http://www.tacomaworld.com/forum/tirecalc.php
Old 01-25-2013
Tiki's Avatar
Ahhh i see, that makes sense thanks for the reply
Old 01-25-2013
sl33pyriceboi's Avatar
If you go keep the same rim size (15") and have a smaller sidewall (like running a 185/55-15) your speedo will be thrown off. It will show that you're speed is faster than what it really is.*
Old 01-25-2013
Low `n` Slow
NAcaRice's Avatar
NAcaRice is an unknown quantity at this point
Save the cash on low pros and get a nice sexy set of aftermarkets on low pros
junkyardguy
20
09-06-2015 10:07 PM
junkyardguy
09-02-2015 06:07 PM
TheRubixHorse
07-29-2015 05:22 AM
JKWood
07-28-2015 03:45 PM
BootyDo
07-07-2015 06:06 AM
Quick Reply: Sidewall on steel wheels
