New Brakes
Rep Power: 0 New Brakes
In about 300 miles im gonna need new brakes. im wondering if it is something i could do myself or have some do it. and i should use the honda pads or is the something better i could use instead of the oem pads.
Thanks
Thanks
Rep Power: 0 when you say "cut," do you mean resurfaced? If that's the case, my brakes are still smooth after the first brake pad change and I didn't get the rotors resurfaced.
It's almost time to change my brake pads again, and I don't think i'm gonna get it resurfaced. Maybe on my third brake pad change.
I like the AEM pads I'm using. I never really got squeaking. It only squeaks when I'm reversing.
BLDNPSI Mod
Rep Power: 304 its always best to resurface the rotors to ensure maximum surface contact between the new pads and the rotor and to also elimanate any rotor runout. It's sometimes better to just replace the rotors because as you machine them you lessen the mass of the rotor and this means less material to absorb heat, that menas your brakes will wear faster, and rotors will develop runout sooner too. Also there is a discard thickness and a machine to thickness that you should take in to account. Never machine beyond the discard thickness. And when installing new pads never machine past the machine to thickness
Jap-Euro Fusion
Rep Power: 400 Dump the stock rotors... they overheat way too easily, and its so cheap to get Brembo blanks to replace them.
After last weekend, I'd highly recommend Axxis Ultimate pads. On the track I had incredible bite and no fade at all. 1 bit of warning on them, they're a little dusty, so if you want to put some effort into keeping the front wheels clean, you can get a whole brake job, thats pads and rotors from www.importrp.com for about $130 ($30 per rotor, $47 for the pads +shipping) and they got my stuff to me in about 5 days (WA to IN, thats fast).
Rep Power: 264 i upgraded to the power slot/ ebc green stuff package from dezod.
http://www.dezod.com/pd_7thgen_brake...eal_2power.cfm
they rock great inprovement!!!
I'd recommend just going with some Brembo blanks and some Hawk or Porterfield pads. Hell, if you don't mind dust, AEM would be good too. I'm not saying don't look at that brake package up there, but it seems people are having some funky issues. Don't get me wrong, when you want to stop, you stop. That I can definately say. There's just something else there. Maybe warped rotors or glazed pads. I'm not too sure.
The Evil Genius
Rep Power: 0 buggin.. get some brembos cross drilled .. oem replacements.. what i mean by that are they are the same size as the oem.. and get some bendix brake pads.. very cheap, low dust.. alot better than oem... and you can resurface cross drilles just like oem.. i have this setup for alomst two years know and only change the pads once and resurface once.. it was my first mod.. im telling you cant go wrong.. just look on ebay you'll find them
Rep Power: 0 Does anyone have any opinion on any of the bendix brakes, either the iq or ct3 models. i think im gonna do it this weekend they are really starting to make moise now. i think for me the hawks are overkill. i just want something that is gonna do better than oe.
Rep Power: 429 yea, I have noticed everyone that has ebc pads, has problems with shaking when they brake. I sure do. And the pads dont last long. Dont get me wrong, at first they are great, but it has only been around 5000-8000 miles and they are almost gone.
Rep Power: 0 I was reading in other posts, that if you use any other pad material other than oem on a stock oem rotor that the rotor will be ruined. and your braking will go to ****. does anyone know if this is true. if so ill have to buy the brembo blanks i guess.ill be installing the new pads this week and they are ceramic not the oem organic. any info would really be appreciated.
Thanks
Thanks
Bricoleur
09-09-2015 06:48 PM
thaler4cuse
09-07-2015 08:25 PM
Josh 1973
09-07-2015 10:10 AM
