Braking Vibrations
Old Jun 12, 2003
Screaming Fist's Avatar
Screaming Fist is an unknown quantity at this point
Unhappy Braking Vibrations
Mk, so my car has about 14,200 miles on it and when I brake at high speeds, there is a little bit of vibration in not only the brakes but the wheel kinda vibrates a little bit too. This only happens when I'm braking, not when driving so I don't think it's that the tires aren't balanced properly.
Old Jun 12, 2003
robbclark1's Avatar
Retired suspension supermod.
your rotors might be warped
Old Jun 12, 2003
What does that mean?
Old Jun 12, 2003
Zzyzx's Avatar
Autocross Junky
yup, sounds like warped rotors, or a misaligned front end, That does that sometimes. If they are warped, youll need to purchace new ones, but with that few miles on it, the dealership may fix it under warrenty.
oh ya, Rotors are the Disks that your brake pads get pressed against to stop the car.
Old Jun 12, 2003
Hmmmmmmmm, how do they get warped?
Old Jun 12, 2003
Zzyzx's Avatar
Autocross Junky
Heat. They can warp from excessive braking (Like durring autocross or driving down Mountain roads) or by getting hot, then you drive throug a puddle and Poof! warped rotors. (Heat causes metals to expand, cold makes them contract.
So If a rotor is very hot and is cooled quickly, think puddle, then the difference in temp of the Hot parts of the rotor (expanded) and the now cold part of the rotor (contracted) cause the area inbetween them to streach, thus warping the shape of the rotor. Warping a rotor through hard braking is a simalar process but it takes longer and ushually dosn't warp the rotor as much.
also the Sock rotors arn't that great any way, they are infact prone to warping. I'd suggest getting a set of Brembo or other such reputible brand of rotor manufacturers rotors. You dont need drilled and/or slotted rotors either, those are for Looks and in some cases performance applications.
Old Jun 13, 2003
Ok, I'll give the dealer a call today to see if it's covered under warranty at all. If it's not, I guess I'll just get some new rotors. Is it often that rotors warp like that? I mean, what type or brand of rotors should I look for to avoid having this happen again?
Old Jun 13, 2003
BlueBullet's Avatar
BlueBullet is an unknown quantity at this point
def. sounds like warped rotors. My Honda Dealership said they have to replace brakes if the breaks have less then 10000 miles on them. Try to get Honda to extend that
Old Jun 13, 2003
Steely's Avatar
Steely is an unknown quantity at this point
Rotors are considered a "wear" item and are not covered under warranty, outside of 12,500. You can have them "turned" at any brake shop for a price of anywhere from $8.00 ea. if you take them off the vehicle. to $100.00 if they have to take them off. Resurfacing them makes them like new again. It shave's millimeters off the rotor and makes it true again. You can do this process usually 3-4 times per rotor. Then Replace them. I dont suggest replacing them at 14,000 miles. You'll get into some un needed replacement and money. There's my .02
Old Jun 14, 2003
aznboi64's Avatar
aznboi64 is an unknown quantity at this point
almost the same problem
My brothers car is kinda like that too, but how can it be warpped when he doesn't race or do anything spirited racing related. Basically even when going under 30mph and you brake slowly the pedel has a slight vibration you can feel. And lets say I do bring it back to honda will I get some BS saying that I lowered the car and changed the suspension so the warranty is void?
Old Jun 16, 2003
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
My 88 civic does this just going down a hill and breaking at the stop sign. Humm have to look into it. The car has 255K on it so who knows what may be going out.
Nick
Old Jun 17, 2003
jro's Avatar
jro
jro is an unknown quantity at this point
read this. it's a very interesting article.
-jro
Old Jun 19, 2003
Isaiah1975's Avatar
Isaiah1975 is an unknown quantity at this point
you need to get your breaks resufaced and it wouldnt hurt to get your pads replaced. Honda here in san jose, said it would cost about $300.00 to do. damn it almost seams like you could get new roters and pads for less then that and have a friend do it. if ts not that then you might need to just get your tires balenced, you should have those checked first.
Old Jun 24, 2003
chibOi's Avatar
chibOi is an unknown quantity at this point
hey.. i was just wondering what happened in the end.. cuz i have the same case..
Old Jun 24, 2003
trashguy's Avatar
trashguy is an unknown quantity at this point
Just get your rotor turned it sliek $7 at pep boys... I go through rotors like crazy do to the crazy Touge i live near hehe....
Old Jun 24, 2003
chibOi's Avatar
turned? what do they do? is it safe to do this? thanks.
Old Jun 24, 2003
trashguy's Avatar
The pretty much put them on a lathe and take off a few thousandths or so until the rotor has an evenly flat surface... You usally can get your rotors turned twice before you have to replace them.
Old Jun 26, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
What the heck is a "crazy Touge" ?
Old Jun 26, 2003
I was kinda wondering that myself
Old Jun 26, 2003
Well, it was only covered under 12/12 warranty (12 months, 12k miles).
So, until I figure out what I wanna do, I'll just live with it I guess.
.........Unless that is going to damage my car...
Old Jun 26, 2003
Ronin's Avatar
I don't think it will damage your car. The only this is, the vibrations may get progressively worse, until it becomes a safety hazard during emergency braking situations.
Old Jul 1, 2003
***UPDATE***
Mk, well, my brakes started making a scraping sound on top of the pedal vibration so I called up my local Honda dealer yesterday and the guy was like "Blah blah, blah blah blah blah, blah, blah blah, blah $295 plus tax, blah blah" I was like
So I said sign me up bish, I'll see you nine tomorrow morning sharp. Early this morning, I took my car to my local Goodyear and said check my brakes. Hour and a half later, they call me and say that the right front caliper is bad, some sort of hydraulic problem and that it's covered under warranty. I was like They didn't charge me for the brake check either so the whole brake fiasco is totally free! Weeeeeeeee!
So I took it to the Honda dealer, they looked at it, called me back and said they will get the part in tomorrow and call me up when it's ready.
But I'm kinda curious, what would cause this to happen to my right front brake system......thingy......in the first place?
Old Jul 3, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
i used to have some nasty brake groan and vibrating pedal action when i first got my car. i changed to crossdrilled/slotted rotors with nissan pads. brake groan and vibrating gone.
however after checking the Vehical issue / problem forumn. i have found that this was a TSB. take it to ur dealer and complain. hopefully they will fix it for u.
Old Jul 11, 2003
Dr5D's Avatar
I notice sometimes my brakes will like 'chatter' when i like slam them on from going fast. like when Im doing about 80mph and I have to turn now, then they kinda shake, but i figure its just the ABS
cncnut
Aug 23, 2015 01:25 PM
GritzNGravy
Aug 19, 2015 03:03 AM
Low_Lupe
Aug 17, 2015 10:57 AM
alaga
25
Aug 13, 2015 04:42 PM
honda.lioness
Aug 6, 2015 11:58 AM
